Q45 caliper+caliper bracket+rotor test fitted
After reading through maxmaxima91's J30 brake conversion thread, in which someone mentioned that Q45 calipers were also the same, I decided to try this upgrade myself. I found a set of calipers at a junkyard a few days ago and got a set of rotors today. I did some test fitting earlier this evening and out that there is only one problem which keeps this upgrade from being bolt-on.
Basically, the Q45 caliper bracket is a little shorter in height than the normal bracket. Due to this, the bracket cannot be bolted on, since it hits the rotor. This can probably be solved by machining the rotors down by about 3mm. I am going to send the rotors to a machine shop and see if that solves the problem. There are two other things which need to be done for this upgrade. One is modifying the dust shield, which needs to be bent backwards very slightly where the upper edge of the caliper bracket hits it. The other is adding two washers to the bracket bolts, so that the bolts don't stick out past the hole. You can also possibly use shorter bolts. To see if the caliper clears the factory 15" wheels, I bolted the caliper assembly without the rotor and fitted the wheel on. There was about a fingers' space between the caliper and the wheel.
This is what I have found out about this upgrade so far and I will post updates as they come.
2 piston..
es amixam, u state that there was about a fingers distance between the caliper and the wheel, does that mean it'll fit stock wheels????? if so, i guess ill be looking for some j30/q45 calipers..
I didn't say the calipers are 2-piston? Oops!
Yes, they do fit the stock wheels, since the early (I think all 1st gen)Q45 wheels are also 15". That's what attracted me to this upgrade.
If you go to the original J30 conversion thread, there is more info+pics there.
Also, for those of you who are wondering, the Q45 caliper bracket is no thicker than the Maxima bracket.
Brian: I used a Q45 rotor, but also tested the stock rotor to see how it would fit under the caliper.
Jon: The caliper does not fit, but it might with some grinding on the torque member. It hits the pad clip on both sides.
Oh yeah, one more thing I forgot to mention: If the stock caliper bracket is installed over the Q45 rotor, the pad clip rubs on the rotor from both sides. Also, the notches for the brake pads on the Q45 bracket are smaller than the Maxima bracket.
so how did the stock rotor fit?
Jeremy
Using the stock rotor with the Q45 caliper would have two disadvantages. One, as Jeremy mentioned, is that the piston would be pushed out further. Two, and this is only my hypothesis, is that the stock rotor is designed to withstand the force of only one piston. The force of two pistons would possibly lead to premature warpage of the stock rotor, which is significantly thinner than the Q45 rotor. Again, this is purely hypothetical, and I may be wrong, so feel free to correct me.
lemme see if i follow this correctly...
q45 caliper bolted on max - clears oem 15" wheel
stock max rotor diameter = stock q45 rotor diameter
q45 stock rotor thickness > maxima stock rotor thickness
can't use max brake pads on q45 calipers
q45 caliper grinds on stock/q45 rotor when installed on maxima
are the brackets between the two calipers interchangeable? i would think not but had to ask.
what part of the caliper hits the rotor? by machining the rotor down did u reduce the contact area of the pad?
Let me put it simply. There are two ways you can do the swap:
1. Mill 3mm off radius of rotor. Bolt Q45 rotor/caliper/TM on. End of story.
2. Grind sides of Q45 caliper to fit inside Maxima TM. Grind inside of Maxima TM to accomodate Q45 rotor. Space Q45 rotor out 1/16" from behind.
Hope this explains everything.
Originally Posted by Jeff92se
Here's a question. How do you actually like them?
If you need a set of spacers.. i have some layin around....
Also, i know this questions wasnt directed at me... but im very happy with my brakes. They feel nearly stock with a bit more power. But knowing that there is alot more mass(to absorb heat) in the entire brake system makes me much more comfortable on the roadcourse.
Jeremy
Jeremy
tarun900
19
12-20-2021 06:57 PM
04-16-2020 05:15 AM
trsandrew
10-25-2015 02:47 PM
Pied
09-26-2015 03:29 PM
