Issue With Broken Power antenna mast.
Old Jun 4, 2001 | 07:32 PM
TSI-HEC's Avatar
Hello to all the fellow Maxima peeps.. Im am new to the board.. Looks interersting alot of info here.. anyways I have A Question Recent the chrome Bezel that surrounds the power antenna base somehow was taken off My 90 Max..after that the antenna would not go down... Recently it was bent so it broke.. I would like to know if I can Just replace the Mast ? or do i need to replace whole POWER ANTENNA ?
Any Help would be Appreciated ,
TSI HEC NYC>...
90 MAX-->STOCK FOR NOW
88 Chrysler Conquest.. TURN UP THE BOOST... ( 15lbs )
Old Jun 4, 2001 | 07:44 PM
Sarah99GXE's Avatar
Maxima Princess
As long as your motor is not burned up you should just be able to replace the mast (at least I was just able to do this to mine when it broke & got bent). I ended up paying $120 just for the mast itself and labor.
Old Jun 4, 2001 | 07:53 PM
hadman's Avatar
The Mast
If the motor is burnt - that is tricky to install and isn't cheap. However, replacing just the mast should cost nowehere near $120, unless you have it done for you as Sarah here did.
It's just too simple to do yourself to justify spending the labor cost.
I just bought one a year ago (when mine broke) for $50. Installation is easy - about 15 to 30 mins. It is entirely possible that the teeth on your current mast aren't set in the cog properly.
It may be found even cheaper now then what I paid. Look on eBay or http://www.usedmaximaparts.com and see if you can find one.
Good Luck!
Hadley
Old Jun 4, 2001 | 08:41 PM
Sarah99GXE's Avatar
Maxima Princess
Re: The Mast
Good Luck!
Hadley
$120 is what happens when you have a good expensive mechanic & dont feel like trying to do it yourself
Old Jun 4, 2001 | 09:06 PM
hadman's Avatar
I know Sarah...
I went to my guy as well initially...then I got cheap.
Old Jun 5, 2001 | 07:18 AM
C-Dawg's Avatar
[QUOTE]Originally posted by TSI-HEC
[B]Hello to all the fellow Maxima peeps.. Im am new to the board.. Looks interersting alot of info here.. anyways I have A Question Recent the chrome Bezel that surrounds the power antenna base somehow was taken off My 90 Max..after that the antenna would not go down... Recently it was bent so it broke.. I would like to know if I can Just replace the Mast ? or do i need to replace whole POWER ANTENNA ?
Follow these simple instructions.
1.) Go to http://gen3.4mg.com/
2.) Click on "Library"
3.) Click on Power Antenna Replacement/Repair
There are detailed instructions with pictures, a step-by-step guide, a "tools needed" list, and the part # for the replacement antenna mast.
The instructions tell you how to do everything. If you have any questions, post them here and I will try to help you out as much as possible.
lowpost99
Oct 26, 2025 06:53 PM
cruce91
Sep 20, 2015 10:23 AM
Maxima30
Sep 7, 2015 06:13 PM
maximusrising
Sep 4, 2015 06:31 PM
trungg86
Sep 4, 2015 04:58 AM
