injectors installation questions
Will do this tonight. Any one knows how much torque required for the injector hold down screws? I mean the cap that hold down the injector into the fuel rail? I can't get this info anywhere.
Also, i need to remove the fuel rail, any gasket behind it?
The fuel rail is hold down to the manifold only by several bolts with about 2 ft/lb torque?
Thanks much in advance.
Denga
Denga
I just swapped my injectors a few days ago, and I luckily had my full set of injectors still in the rail. I couldnt get those phillips screws out to save my life. I was thinking you'd have to use a big pair of vise grips or something. I'd replace those screws with a allen or hex head bolt if you have the opportunity. It would make removing them alot easier if you diy next time. I wish I had the time but I didn't.
~Alex
~Alex
Thanks for the reply. I will use a locking plier to remove the screws.
if i understand you right, you swapped the whole injector rail with all the injectors in it. Did you see any gasket, O-rings between the fuel rail the the manifold?
Thanks.
Denga
Thanks.
Denga
yea there are large orings, they are about 1/16 of an inch or 1/8th.I just reinstalled them after putting a little oil on them. Seems to be working.
Of now I find out theres a leak when I fill up my tank and I have a coolant leak. Yay more stuff to fix ><
~Alex
~Alex
Denga
Denga
Originally Posted by Hectic
hey Al, would you mind selling me one or two working injectors from the rail you pulled. i've got a single faulty injector on one of my cars, looking for a cheap and quick fix.
~Alex
Originally Posted by CnR's 90 max
what is the proper ohm reading
Power balance check would be better way to check.
Injectors on these car are known to cause trouble.
Good luck.
Denga
One more thing, i found the pulling out the whole fuel rail first then it would be breeze to tapping out the bad injectors with a rubber mallet gently, one second a pop. Also using a locking plier to remove the screws was just so easy.
Denga
Denga
It should be around 12 ohm. But eventhough all my injectors measured ok by resistance, they are all shot. This happened after i used some STP super concentrated fuel injector cleaner a month ago.
Good luck.
Denga
Good luck.
Denga
maxprivate
11-29-2017 08:52 AM
Finkle
09-27-2015 09:53 PM
Ray229Harris
09-16-2015 08:16 PM
