airbag light is on
Old Jan 31, 2006 | 09:47 AM
zx2max's Avatar
airbag light is on
i have to go to motor vehicle today. will i failed inspection because my airbag light is on? Also, is there a self diagnostic for it or a way to make it go out?
Old Jan 31, 2006 | 09:52 AM
Greeny's Avatar
¯\(°_o)/¯
Take the instument cluster out and remove the airbag light bulb....Or take it to the dealer and spend bunches of $$ to fix it....
Old Jan 31, 2006 | 10:37 AM
internetautomar's Avatar
mod or sell?
pull bulb = instant fail for tampering with safety equipment
no clue how to fix it, my FSM is in the bedroom
Old Jan 31, 2006 | 12:43 PM
maxitech's Avatar
I'm glad my state doesn't test emissions, inspect vehicles, or anything else of the sort. Then again, if they did, the roads around here would be wide open!
Old Jan 31, 2006 | 12:51 PM
Sgibb's Avatar
pull the bulb they'll never know
Old Jan 31, 2006 | 01:25 PM
tripleGmax's Avatar
except its supposed to come on when you start the car, if they look close enough and it doesnt come on, then they could investigate and get you for that.
check the fuse maybe....
Old Jan 31, 2006 | 01:27 PM
zx2max's Avatar
i just got back from motor vehicle and they didnt even look at the dash for any lights. i passed without a problem. My 97se on the other hand, when i took that car to motor vehicle a couple months ago it failed because of a check engine light even though emissions and everything eelse was fine.
Old Feb 18, 2006 | 12:56 PM
dadsmax's Avatar
I am thinking a clock speed in the steering wheel? Maybe?
Old Feb 27, 2006 | 11:57 AM
bgssamson's Avatar
Got the same problem, it keeps blinking. Maybe someone with experience fixing this can chime-in.
Thanks!
-Brian
Old Feb 27, 2006 | 03:02 PM
vansskaterfreek's Avatar
isnt there a recall on the air bag system?????
Old Feb 27, 2006 | 06:49 PM
JRS89MAX's Avatar
I know in New York if your check engine light is on they suppose to NOT start the inspection or charge you cause youll automatically fail. Some like to get over and dont say anything.
Old Feb 28, 2006 | 06:21 AM
bhunter's Avatar
There is a way to reset the airbag light. It will probably come back but it is worth a try. open the door and turn the ignition to ON (not start) within 7 seconds of turning the ign on press the driver's door button 5 times. ( the little rubber covered button in the door frame) Turn the ign off, then start car.
Old Feb 28, 2006 | 09:00 AM
bgssamson's Avatar
Thanks! I will try this later tonight.
-Brian
Old Feb 28, 2006 | 11:49 AM
jrogers's Avatar
I'm having a related problem. Last week, the airbag light on my 93 SE lit up. At the same time, the automatic seatbelts stopped working when the ignition is in the off position and my clock memory doesn't work (and is suddenly VERY dim, when you can see it at all). As soon as you turn the key, the automatic seatbelt starts working again and the clock starts keeping time at 12:00. The airbag light stays on. I'm assuming that somewhere the always on power is shorted or something. Anyone have any experience with this or any ideas where to start looking. Or am I barking up the wrong tree entirely? Anyone have wiring diagrams for these systems?
Thanks in advance for any help you can give me.
Old Feb 28, 2006 | 11:54 AM
bhunter's Avatar
Sounds like you blew your "Electron Batt" fuse.
Old Feb 28, 2006 | 11:58 AM
bgssamson's Avatar
I was seaching it at nhtsa.dot.gov website & here's what it says:
Does any have there 3rd gen fixed by the dealer bec. of this?
-Brian
NHTSA Action Number: NHTSA Recall Campaign Number:
EA93024 94V007000
Make: NISSAN Model: MAXIMA
Manufacturer : NISSAN NORTH AMERICA, INC.
Year : 1993
Component :
AIR BAGS
Date Investigation Opened : October 8, 1993
Date Investigation Closed : January 25, 1994
Summary:
There is no summary currently available
Check to Request Research. Submit below.
Old Feb 28, 2006 | 12:03 PM
bgssamson's Avatar
-Brian
EA93024 94V007000
Year : 1993
Component :
AIR BAGS
Summary:
Old Feb 28, 2006 | 02:35 PM
jrogers's Avatar
Thanks. That's exactly what it was. Thought I'd checked all the fuses . . . must have missed that one. Grrr.
Old Mar 1, 2006 | 05:45 AM
bgssamson's Avatar
-Brian
This did not work for me but I will try to check the fuse.
Thank you,
-Brian
Old Mar 1, 2006 | 08:42 AM
alextothestars's Avatar
mine didnt come on until i ran a diagnostic via the ecu. seems like it found out it was bad and now it wont go away.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
Colossus
Sep 9, 2015 05:46 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
