Grinding noise at 1300-2000rpm range
Old 01-10-2006, 11:03 AM
chrgdRapa's Avatar
heya, i was wondering what would make that noise,
its basically a grinding noise i hear when im on idle stopped at a light or something, and its periodic, so it 'grinds' every second or so. its coming from the engine i think, i can slightly feel it on the pedal too. so when i accelerate from 0, it grinds at about 1300 until about 1900 rpm then stops. car runs okay even while it grinds. when on PARK, it has a periodic grind noise too, then when i accelerate in the engine bay using the throttle cable i hear the grinding noise coming from the left side of the engine.
anyone have any ideas to what could it be?
thnx
chrgdRapa is offline
Old 01-10-2006, 11:32 AM
Suprise butsechs!!!
Dillbag's Avatar
bad water pump?
Dillbag is offline
Old 01-10-2006, 07:02 PM
subs1000w's Avatar
if it does it while parked why not pop the hood and listen in that area to see if you can pinpiont it if its a belt driven accesory start removing belts untill it stops and then you know what it it
subs1000w is offline
Old 01-10-2006, 07:04 PM
vansskaterfreek's Avatar
when i heard grinding noises.. it was coming ffrom my transmission... week later the car wouldnt move
vansskaterfreek is offline
Old 01-10-2006, 10:07 PM
Suprise butsechs!!!
Dillbag's Avatar
yeah, could be the trans. too...
a long screwdiver or prybar makes an excellent s***hiscope, just put the tip on the part you want to listen to and put your ear onto the handle.
Dillbag is offline
Old 01-11-2006, 07:50 AM
Phatsta's Avatar
that makes two of us, mine because of a faulty trans oil pump...
Phatsta is offline
Old 01-11-2006, 03:24 PM
a long screwdiver or prybar makes an excellent s***hoscope, just put the tip on the part you want to listen to and put your ear onto the handle.
thats what i did with my belt pulleys... found out that my A/C idler pulley was bad
Old 01-11-2006, 05:05 PM
Suprise butsechs!!!
Dillbag's Avatar
oh yeah, forgot about the belt pulleys, could be that too.
so let's rehash, could be the following so far:
water pump
tranny
belt idler pulleys
t-belt tensioner pulley
anything else?
Dillbag is offline
Old 01-11-2006, 06:15 PM
SNIPA
Can Some One Please Help Me 2 Get My 92 Maxima 2 Start And Run Da Previous Owner Told Me It Need A Head Gasket Sum Struts And A Heat Core My Aunt Drove It From Orlando 2 Georgia And It Broke Down In Macon Before It Even Got 2 Me I Got It Towed 2 My House And On Monday Im Gon Get It Delivered 2 A Shop Where All I Gotta Do Is Pay For Parts And I Help Wit Da Labor Free Labor Da Speedometor Also Dont Work And Probably Some More Stuff Any Suggestions Please
hcarter1112
42
07-18-2022 03:35 PM
Miket2006
03-01-2021 03:55 AM
D Mason
06-21-2016 04:43 AM
uttadms31
09-30-2015 05:24 AM
Quick Reply: Grinding noise at 1300-2000rpm range
