Power Steering Noise?
Old Jan 14, 2006 | 12:19 PM
hoyshnin's Avatar
Baby's on the Half Tip!
When I turn the steering wheel either way, there is a groaning noise, like when you turn the wheel as far as it can go. Is my power steering fluid maybe low? What else could be the problem?
Also, where is the reservoir for the power steering fluid? I have a 92 SE. I'm thinking it's on the left side of the engine bay in a black unmarked plastic cylinder type thing, is this right?
Thanks for your help.
Old Jan 14, 2006 | 12:24 PM
vansskaterfreek's Avatar
yup it is on the passenger side... fluid is either low or you have air in the line or the pump is going bad
Old Feb 1, 2006 | 12:32 PM
wmeacham's Avatar
Fluid is low. If it leaks out after you fill it you will probably have to replace the hose to the reservoir.
Old Feb 2, 2006 | 01:50 PM
stephencu2004's Avatar
Is there a way to get the air out of the line? I replaced my hose last month and now it makes this noise too, didn't before just leaked so I had to change it.
Old Feb 2, 2006 | 02:00 PM
Greeny's Avatar
¯\(°_o)/¯
This is the bleeding procedure per fsm....
Old Feb 3, 2006 | 11:27 AM
Thank you so much I will try that this weekend
Old Feb 4, 2006 | 11:56 AM
Tsukasa's Avatar
Il'll try that me to because i have the same noisy steering pump sound !
Old Feb 4, 2006 | 12:51 PM
slickblack94's Avatar
Is it also true, that nissan put tranmission fluid in the p/s pump?
I've had the noise since I changed the high pressure hose. I did'nt
jack up the car and go from bumper to bumper like stated above.
I too, will try this afternoon to see if this"burps" the system.
Old Feb 4, 2006 | 03:01 PM
Greeny's Avatar
¯\(°_o)/¯
All nissan p/s systems take dextronIII trans fluid....
Old Feb 4, 2006 | 03:08 PM
does it HAVE to be trans fluid, or can it be powersteering too?
Old Feb 4, 2006 | 03:19 PM
SouthStar019's Avatar
ive added powersteering steering fluid to my resivor also. idnt notice any thing. this be b4 i knew it used the same fluid as the tranny.
Old Feb 4, 2006 | 05:18 PM
bump...... started drinking, will try tomorrow.
Old Feb 6, 2006 | 09:21 AM
o.k....I jacked the car up, then went bumper
to bumper by turnring wheel both ways till
it stopped.Then I let it off the jack and did
this again with the car running. seems to
have a slight noise still. I wonder if thats
because I put p/s fluid in and not the auto
trans fluid nissan put in it from factory?
Well enough with that.On to installing the CAI
I got from brian.
Old Feb 6, 2006 | 12:32 PM
MyBlue92Maxima's Avatar
i have a noise only when i start the car, since i park on the street infront of my house i need to turn the wheel to pull out, it makes a nice loud squeeking noise, only happens when i first start the car, car can be warm or cold. from what i hear it could be my power steering belt comming loose? anyone else have any ideas?
Old Feb 6, 2006 | 01:05 PM
just tighten the pulley... if you are still coming friday, ill take a look at it
Old Feb 6, 2006 | 04:38 PM
Greeny's Avatar
¯\(°_o)/¯
I got from brian.
It would probably be a good idea too get the regular p/s fluid out of the system....It is not the right fluid,so it may cause pump damage in the future.
You should have left the car on the jack when it was running too..
Old Feb 6, 2006 | 05:01 PM
Maxzilla91's Avatar
WTF?? tranny fluid in power steering? i just went and topped off my PS reservoir with power steering fluid!!
Old Feb 6, 2006 | 05:19 PM
Greeny's Avatar
¯\(°_o)/¯
Do any of you guys have one of these in your glove box!!!????
The equivalant to dextron II is dextron III transsmission fluid.
lowpost99
Oct 26, 2025 06:53 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
