Can I fit this into a 3rd gen?.....steering wheel.....
I would imagine the steering wheel would fit, but you would not be able to use the airbag, unless you did some serious wiring with the sensors and everything.
It doesn't look like the steering wheel has cruise control, either, so you would lose that, unless you rewired it.
You could just install it and enjoy the look, then hope no one steals the airbag out of it
I have a steering wheel out of a 240 sx that has the cruise buttons. Everything works like normal.
airbag is not a problem at all. I was planning on rewiring the cruise which will not be a big deal at all....man, that wheel will make such a difference...can somebody tell if the hole diameter is the same though?
dont quote me but i belive all nissans after 89 have the same hub. i think there is a list on sr20forum on the wheels that fit different cars. the clock springs are different, since your 91 has no airbag right.
