VTC rebuild question
Old Jan 28, 2006 | 10:21 AM
92 Max's Avatar
I'm rebuilding the VTC's on my 92 Max SE and have come across a problem. My next step is to remove the right, front, upper timing chain cover and I can't figure out whether to remove the idler pully for the a/c belt. The manual is no help here since it doesn't show this pulley mounted. The book says just remove the cover bolts and pry it loose, but I can't see two of them and I hate to remove most of the cover bolts and have the pulley tension bend the cover (if it's attached). I can't see it too well even with a mirror since things are so close there.
Has anyone done this and is the pulley in fact attached and do I have to remove this idler pulley to remove the cover. ( I hate to remove more than I need to, since I have to put all of it back afterward, and, more importantly, REMEMBER to put it all back)
Old Jan 28, 2006 | 02:04 PM
MrGone's Avatar
It's bolted to the front 'side valve cover' with 3 bolts IIRC.
if you are free around 10:30ish AM M-F I can stop by and lend a hand for a bit
Old Jan 28, 2006 | 03:00 PM
92 Max's Avatar
Thanks, I didn't want to bend the cover forcing it when something was attached.
Thanks for the offer. I'm not around then, and I'm trying to do this by myself. But if I start to drownd I'll check back.
Old Jan 28, 2006 | 03:17 PM
bhunter's Avatar
Mr. Gone, would you like to move to Kansas? I bet I can find you a job.
Old Jan 29, 2006 | 12:48 AM
MrGone's Avatar
I like it here
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Pied
Sep 26, 2015 03:29 PM
