bulbs in dash switches
Old Feb 5, 2006 | 08:30 AM
andy044's Avatar
RWD bolt-on conversion?
so some were burnt so i took out all switches and replaced some with bulbs that i took off the l.rover disco. in my avatar.
anyways
how do i get at the fog light bulb in the switch?
i could get at all the other ones out from the back or with the ccontrol i had to take off the rocker switch cover.
the rear defrost looks like the same as the fog light switch. but that one isnt burnt out.
thanks
Old Feb 5, 2006 | 10:44 AM
Michael's Avatar
Back in a 3rd Gen.
anyways
thanks
go to Craigs site and check out the write up I did for installing LED into those buttons. I show how to take them apart.
Good luck
Old Feb 5, 2006 | 01:07 PM
fatboyslim86440's Avatar
there should be clips where the botton it self is secured
just pop them open and there should be 3 or 4 peices inside
replace with bulb like other switches
dunno if i helped any
Kyle Cisneros
Old Feb 5, 2006 | 04:48 PM
andy044's Avatar
yeah thank you asm66 and fatboyslimm
now i just have to remember where the short bulbs came from?
Old Feb 6, 2006 | 11:50 AM
es_amixam's Avatar
radio shack has the bulbs. can't remember the part # but you should see them in the flashlight bulb section. unwrap the old ones from the holders, cut the leads of the new ones to size, wrap them on the holder, and replace.
Old Feb 6, 2006 | 02:03 PM
«§»Craig B«§»'s Avatar
272-1092 or 7219
Old Feb 6, 2006 | 05:22 PM
AH11980's Avatar
LEDs?
Hey was wondering if it would be possible to swap the indash bulbs with high intensity clear blue LEDs? since its a 12 Volt supply you could run them through 1/2 watt resistors.
Old Feb 6, 2006 | 05:43 PM
Michael's Avatar
Back in a 3rd Gen.
go to the write up I did (and mentioned earlier) on Craigs site...that is exactly what I did and the write up is about.
Check the post right above you by Craig. In his sig he has a link to his how to site. My write up is in there.
His site is also in the stickies.
Old Feb 12, 2006 | 10:03 AM
sp3dymax's Avatar
what do you mean by cut them to size?
like literraly cut the bulb ends?
Old Feb 12, 2006 | 10:13 PM
es_amixam's Avatar
Just cut the wires coming out of the bulbs.
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
