Tach Going Crazy
Old Feb 12, 2006 | 04:50 PM
fattamax's Avatar
Tach Going Crazy
My Tach is bouncing around and I dont think that it is reading correctly anyway. This the sequence of events....My harmonic balancer broke and rather than trying to fix a bunch of other crap going wrong on the engine I bought a used engine from the salvage yard....put that in and then like a couple of months later the trans went too. NICE !!! Well my car doesnt seem to shift at the correct times. I was told that the trans computer may have a problem.....After all of that the tach started its craziness. I thought had to do with me changing my GXE gauges to SE gauges. Give me a clue what I need to do or check.
Old Feb 12, 2006 | 05:14 PM
goon9's Avatar
tach sensor is bad.
Old Feb 12, 2006 | 09:35 PM
aminus21's Avatar
where/what is that^^^.... i might have the same problem, my tach is jumps between 1500-2000, and then will suddenly shoot back down to 750..
Old Feb 13, 2006 | 04:20 AM
goon9's Avatar
That sounds like a timing issue, or something else.
Old Feb 13, 2006 | 12:15 PM
fattamax's Avatar
Well that wouldnt make sense that the sensor was bad because i got the problem just a little after the engine was changed....and then when i got the trans changed it really started to be a problem. Now it will completely tach out and stay there and eventually it will respond. So the speed sensor on the trans is what you think.....and not something with the distrbitor ? I hope its something really simple because this car is starting to nickle and dime me to death....and I really dont want to get rid of it for that reason...so help a brotha out !!
Old Feb 13, 2006 | 12:25 PM
goon9's Avatar
OMG I'm sorry. Not the trans sensor. I donno what the hell i was thinking. I was stuck thinking it was the speedo.
Ok, is the tach bouncing with the engine running smooth.
If it is, there's a bad connection either on the gauge, or possibly the sensor, I donnno where the tach sensor would be. Never fooled with it.
Or is the idle shifting with tach?
In that case it can be a number of things.
Really badly gapped spark plugs.
possibly cap and rotor.
spark plug wires.
Timing could of jumped(I had this happen, ran fine most times, ran like crap other times. bogging, high idle, surging.
I'm assuming you know how to check all those things, I saw how much work you did on your car. Good work.
Old Feb 15, 2006 | 05:03 AM
fattamax's Avatar
YES !! You are dead on !! The tach bounces around but idle doesnt change, the car runs well and other times it runs ok, and sometimes the idle is high 1000-1300...but it eventually corrects its self. I am at an end so I may have to just take it to the dealer....at least then if I have a problem afterward I can make them fix it. Theorecticly !!
Old Mar 11, 2006 | 07:34 PM
karzrfun's Avatar
I have the same problem, it is so frustrating the car runs fine but the tach goes crazy. Let me know if you figure it out so i can fix it also. thanks
Old Mar 12, 2006 | 05:46 AM
jewsonlot's Avatar
i had the same problem tried cleaning contacts ect ended up changing the tack it works fine now.
Old Apr 6, 2006 | 12:20 AM
mszilves's Avatar
spark plug wires.
Same problem here. Engine runs perfect, but tack will bounce around sometimes. So has anyone had any luck with isolating what sensor is not working or if it's the tach itself?
Cheers.
ivorton23
Sep 28, 2015 09:08 PM
Garrettz459
Sep 28, 2015 02:50 PM
ColdCananda
Sep 20, 2015 10:45 PM
Maxima30
Sep 7, 2015 06:13 PM
maximaham
Aug 7, 2015 01:11 PM
