how hard is it to replace rear window
Old Feb 19, 2006 | 10:51 PM
red-line-racer's Avatar
well someone f***in smashed my left back door window i wanted to know how hard is it to relpace it and does it just slide in or is there only one way to put it in??thanks i will post pics later today..
Old Feb 19, 2006 | 11:05 PM
Josh's Avatar
1. Pull off door panel 2. unbolt window from regulator 3. Slide out broken window 4. Slide in new window (make sure it tracks correctly) 5.bolt into assembly put everything away. for your first time doing it is should prob take an hour tops.
Old Feb 20, 2006 | 05:58 AM
internetautomar's Avatar
mod or sell?
which window?
the bigger one: see above ^
the little one: see above plus you'll need to unscrew the bottom of the metal piece that seperates the big and small window and tale iy out
Old Feb 20, 2006 | 07:08 AM
Old Feb 20, 2006 | 09:04 AM
cheatham's Avatar
I need a brake.
Put the rear window in the down position.
There are 4 screws holding on the door panel. Take out the ash tray, the plastic plug on the top of the door pull and the plastic insert under the door handle to access them.
After removing those screws, pop off the door panel. Disconnect the two wiring harnesses. With the rear window down you will see the tow bolts connecting the rear window to the regulator. Take those out and let the rear window rest inside the door.
You will now need to loosen the black pillar between the rear window and vent window. You will notice two bolts holding the pillar in place. Remove those bolts. There is also a screw at the top of the pillar, underneath the rubber. Do not take the rubber out, just use a small flat screwdriver to hold it back while you loosen the screw with a phillips head.
At this point the pillar should be loose, pull it down and push it foreward in order to loosen it. I needed to also take the rear window out in order to reinstall the vent "break-in" window.
The vent window rubber will just fall out, and the new vent window will simply slide in and then be held tight by reinstalling the black pillar.
*Probably $20-$40 for vent window from boneyard.
*Make sure to get the rear window back on both tracks when reinstalling.
*Don't tighten regulator bolts too tight.
Old Feb 20, 2006 | 10:31 AM
mod or sell?
Originally Posted by red-line-racer
Old Feb 21, 2006 | 04:15 AM
is this the driver side rear window or the passenger rear
Old Feb 21, 2006 | 05:49 AM
mod or sell?
looks like driver side.
just follow the curve of the glass
Old Feb 21, 2006 | 06:05 AM
Josh's Avatar
Maybe I'm seeing things but with the curve sloping to the left and window bowing out that looks like a passenger rear....but maybe I'm missing something.
Old Feb 21, 2006 | 06:24 AM
mod or sell?
isn't the part that hangs down towards the rear?
oh well, I may be wrong
Old Feb 21, 2006 | 06:34 AM
Greeny's Avatar
¯\(°_o)/¯
This looks to me like the passenger side glass....
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
