Cold RPM Hesitation
Old Feb 23, 2006 | 11:03 AM
Red89maxima's Avatar
Cold RPM Hesitation
Okay guys, I've exhausted my ideas on this one! Whenever I start my car after sitting for about 2 hrs, there's a huge dead spot in my rpm's where if I give it any fuel it falls flat on it's face. Only if I ease into it though. If I give it a quick rap it's not very noticable at all, but it's still there! After warming up it seems to dissapear, but even then there's a varience in my rpms. They go up then down, then up, then down. It's not throwing a code, it has new plugs, wires, and O2 sensor. I haven't changed out my injectors, but I've checked them and they all seem to be firing normal. Any other ideas?
Old Feb 23, 2006 | 12:26 PM
Greeny's Avatar
¯\(°_o)/¯
1.bad tps [throttle position sensor]
2. bad/dirty maf [mass air flow sensor]
3. Dirty connectors on both
Old Feb 23, 2006 | 04:18 PM
internetautomar's Avatar
mod or sell?
check to see if it's throttle position related.
see if it always happens at the same pedal position
Old Feb 23, 2006 | 05:04 PM
vansskaterfreek's Avatar
anyone think seafoam will help???
Old Feb 27, 2006 | 04:44 PM
neverendingzz's Avatar
Rpm Issues
Hello guys, for some reason I cannot post a topic so I came into the closest topic related to my 1992 Maxima.
Here goes,
When I accelerate my RPM's drop like crazy and it revs my car with the RPM's flucuating. If I leave my foot on the gas while this is happening it will cause me to stall(most of the time). This does happen at random, mainly when its really cold out and when I am merging on the highway.
I have went to 2(two) mechanics and they both told me that they couldnt figure out what was wrong with the car. they saw what was happening but couldnt do anything about it. There were no error codes read either.
The 1st mechanic fixed the Fuel injector that was bad. That fixed another problem that occured at the same time as this happened. I have been using 93 octane gas as well. I just changed my plugs and my fuel filter. The car will jerk front to back while driving.
Can anyone assist me in the right direction?
Thanks in advance.
Ed
Old Feb 27, 2006 | 05:06 PM
mod or sell?
coil packs
Old Feb 27, 2006 | 05:57 PM
you have the 1992 SE right with the DOHC motor???
Old Feb 28, 2006 | 06:55 PM
neverendingz's Avatar
Yes I have the 1992 Se with the DOHC Motor.
Old Feb 28, 2006 | 07:18 PM
i guess coil packs also!
Old Feb 28, 2006 | 08:27 PM
Doesnt the coil packs either work or dont work. Not just work sometimes?
Old Mar 1, 2006 | 10:21 AM
mod or sell?
sometimes they work right, sometimes not at all and sometimes they don't work right
Old Mar 1, 2006 | 05:55 PM
sometimes they crap out on you when they are stressed out, or like then you put stress on the motor, EXAMPLE: when you step on the gas pedal to move the car.. other times like when idling, they may be fine
Old Mar 2, 2006 | 10:25 AM
Thanks for the advise. It seems like my car now stalls when I am idling at a traffic light. Are these hard to replace? How much do these generally cost. thanks in advance.
Old Mar 2, 2006 | 03:41 PM
they are not hard to replace at all, but they are expensive as hell!
Old Mar 2, 2006 | 04:54 PM
mod or sell?
VE coils are only like $70 ea
Old Mar 2, 2006 | 05:54 PM
$70
x $6
_______
$420 !!!!!!!!!!
Old Mar 2, 2006 | 06:11 PM
mod or sell?
I wouldn't replace all 6 at once.
Old Mar 2, 2006 | 06:16 PM
Greeny's Avatar
¯\(°_o)/¯
$70
x $6
_______
$420 !!!!!!!!!!
http://forums.maxima.org/showthread.php?t=459657
Old Mar 2, 2006 | 06:37 PM
Originally Posted by MyGreenMax94
you guys have answers for everything....
Old Mar 2, 2006 | 07:03 PM
thanks a lot guys. I will check this out and let you all know what happens.
Old Mar 4, 2006 | 09:25 PM
my car seems to now be stalling when I am idling at a light. Would this be a result in the same issue with the possible coil packs problem?
Old Mar 5, 2006 | 06:08 AM
mod or sell?
could be, but more specific information is needed
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
