brake torqueing...
Old Jun 10, 2001 | 10:49 PM
hoey's Avatar
so what can happen if i were to do this a lot...
my friend just told me about it, and i didnt want to do it until i knew what would happen if i did do it =)
Old Jun 10, 2001 | 10:51 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Just have.....
$2000 handy for your trans rebuild in a few weeks!!! trust me stop while you're ahead, one good one can kill the trans before you know it!
Old Jun 10, 2001 | 11:09 PM
superdesi's Avatar
What exactly is brake torqueing?
Old Jun 10, 2001 | 11:14 PM
hoey's Avatar
Da Max... im not talking about neutral dropping...
i know that that can kill your tranny...
Desi... brake torqueing is when you just step on your regular brakes and you rev til about 1.5 - 2k and when the green comes you slam on the gas and let go of the brakes...
was still wondering about the side effects of what i just described above
Old Jun 10, 2001 | 11:26 PM
DA-MAX's Avatar
I know what brake tourquing is....
and by brkae torquing you are turning the engine and thus turning the TC, but by holding the brake preventing the wheels from moving....you are creating IMMENSE heat and stress on the TC and the clutches, bands and servos in the trans, which eventually leads to failure.......our TC stall speed is 1800rpm so torque braking above that IS VERY BAD!!!!! if you must torque brake do it around 1000-1500(which is still bad) or consider getting a high stall TC which will reset the stall speed higher. but either way you look at it brake tourquing IS NOT GOOD!! don't listen to your friends if they are telling you this will not hurt the car, I've personally know first hand what it does.....(ie- my trans rebuild #2)
notice the words and phrases I bolded, if you value your trans DON'T DO THIS!!
Old Jun 10, 2001 | 11:38 PM
DA-MAX's Avatar
And another thing.....
heres my suggestion on a good way to launch, try a "Flash Stall"....basically with your left foot press the brake down (not all the way)to the point where the car will not move. then place your right foot on(but don't press) the gas pedal and on the green just lift left foot off the brake and floor it with your right foot....
IMO, brake torquing yeilds too much wheelspin and is highly dangerous to the trans and to me "flash stalling" proved much more effective (for my track launches) and is much safer for the trans!!
Old Jun 11, 2001 | 12:12 AM
hoey's Avatar
hehe ok thanks... ill try that one out too =)
Old Jun 11, 2001 | 10:46 AM
Jon91SE's Avatar
Pusssseeeehhhh
Yea ive been through many a tranny for that reason as well, id say if you do it, keep it below 2000 and be sure that your holding it for no longer then 2 seconds, i also suggest a tranny cooler if your going to drive your car hard.
Old Jun 11, 2001 | 11:12 AM
flyry110's Avatar
this is why i only drive manuals!
Old Jun 11, 2001 | 03:21 PM
Maximum5spd's Avatar
Yeee, me too. And thats why i hate manuals. (no offense)
Old Jun 11, 2001 | 10:18 PM
flyry110's Avatar
huh?
Old Jun 12, 2001 | 12:09 AM
huh?
sorryi meant to say i hate automatics (no offense)
Old Jun 12, 2001 | 05:30 AM
C-Dawg's Avatar
Re: I know what brake tourquing is....
Originally posted by DA-MAX
IS VERY BAD!!!!!(which is still bad)but either way you look at it brake tourquing IS NOT GOOD!!
The man has a point.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
