Alarm help please?
Old Feb 27, 2006 | 02:34 PM
JRS89MAX's Avatar
Alarm help please?
I activate my alarm with the remote.But the headlights stay on. Deactivate still on.Sometimes its both headlights or itll be the left or the right. I know the headlights suppose to blink off and on when i set the alarm off . But its not doing that. Right now the right headlight is on but i took the fuse out. I hear a clicking in the dash. could it be some relay.
Old Feb 27, 2006 | 02:52 PM
Josh's Avatar
i don't know much about alarms but in the electronics section they have a sticky about wiring setups/diagrams for all gens you might check that if you haven't already.
Old Feb 27, 2006 | 03:22 PM
internetautomar's Avatar
mod or sell?
my guess would be a bad relay on the alarm unit
Old Feb 27, 2006 | 04:03 PM
JRS89MAX's Avatar
Through the forum and my chiltons. I found that red/yellow wire is drivers side headlight and red/green wire is the passenger side headlight. So those two wires should direct me to the relay or two relays (1 for left HL and 1 for right HL? Which makes my light flash when alarm is set off.
Old Feb 27, 2006 | 04:57 PM
mod or sell?
look at Craig's website for wiring info
Old Feb 27, 2006 | 05:27 PM
JRS89MAX's Avatar
Yeah i checked it out but nothing about relays.Went outside to check wiring on the car. Had to take out bottom of dash. Found 3 relays. Gonna work on it in the morning parts stores closed . But i think this is it. Thanks for the help.
http://www.the12volt.com/relays/page4.asp#lf1
In this site im thinking it'll look like the 2 WIRE LIGHT FLASH.
Old Feb 27, 2006 | 05:35 PM
bhunter's Avatar
One thing to try--- When you shut the car off, flip the stem that turns the headlights on forward like you are putting your brights on. One one of mine the stem was a little bad and it would let the lights on by failing into the positon like when you pull the stem BACK to just flash your brights. If that stops the problem it may not be your alarm but the stem instead.
Old Feb 27, 2006 | 05:46 PM
JRS89MAX's Avatar
I think its the alarm. Cause when i reseted the alarm buy putting the key on on and pressing the cut off switch. It would turn the headlight off Then a lil while later it'll come back on. But now my right headlight is just stuck on. Which i took the fuse out till the morning.
Old Feb 27, 2006 | 11:08 PM
Loco7's Avatar
i can give you a PDF file with everything you'll want to know about hooking up your alarm. send me a email with a subject car alarm
Old Feb 28, 2006 | 01:24 PM
JRS89MAX's Avatar
Thanks for yah help. Found the bad relay. In the drivers side. Inside an opening of the fender. Was wet and dirty. Problem solved.
http://putfile.com/pic.php?pic=2/5815345638.jpg&s=x402
kmitchel
Oct 28, 2015 09:46 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
RussMaxManiac
Jan 3, 2001 06:41 AM
RussMaxManiac
Jan 3, 2001 05:40 AM
