VE into a 89-91 Max
Old Jun 11, 2001 | 03:31 PM
Maximum5spd's Avatar
Hey guys, my friend is getting rid of his car, he has 93 max. He can give me his VE engine for free. Do u think its worth swaping. How much $$$ u think it would cost to swap the engine.
Old Jun 11, 2001 | 04:05 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
All I know......
is I've heard there is more work in it than what its worth for 30 extra horses! I think you have to relocate some stuff and some other little things.... a search might turn up some more answers, I've seen this topic discussed before.
Old Jun 11, 2001 | 04:10 PM
Czar's Avatar
dude its not worth it....Go turbo instead!!!
VG-T power!!! <----in Jeff92SE style....
Old Jun 11, 2001 | 04:21 PM
Jeff92se's Avatar
I'm needing a caw
Hey how's the project going? When can I come over and see all the goodies? We can brainstorm or something!
Old Jun 11, 2001 | 04:50 PM
Czar's Avatar
I ended up having to make a custom front header because the stock one takes up too much of the room where the turbo goes. The turbine side is even with the back edge of the block and the compressor side sits right above the starter. I am running the 1 7/8 crossover under the engine and to a new flange right behind the turbo. The new manifold will be more of a log style to give me more room and will include the additional pipe for the other bank. WIth all the welding going on, I am learning to weld because Stan's will charge me too much to do what I want to do. Its a little more work than I had anticipated, right now I need to find an O2 housing that goes straight down rather than straight back from the turbo. This attachment is similar to what I am doing for turbo placement, but with the c/o under the engine. Do you know where I can get a O2 housing that goes straight down like this one???
Old Jun 11, 2001 | 05:08 PM
Maximamike's Avatar
Oh Czar, I saw your post on Z31.com about rebuilding turboes. I would recommend you bring it to a well known turbo shop and have them rebuild it. It might cost a little more but they can do more stuff to ensure reliability(spin balance to 100k+ rpms, micropolish ****, etc). This way you will get a warrenty with it as well.. Keep up the good work
PS: Get Jeff to the track. Hahahahaha..
Old Jun 11, 2001 | 05:28 PM
Czar's Avatar
I investigated the cost of rebuilding the turbo and for just the kit it is more than what I paid for the turbo(after selling the other junk I got)... So since I have reasonable confidence that it is good(came out of a wrecked car with 68K, and I spooled it up with a vacuum cleaner-- no wierd sounds; spins smooth) I will just bolt it on and if the seals or something else is bad, I'll get a T-3/T-4 with the bigger compressor.
BTW Jeff.. not too much happening, just hacking apart my manifold to modify it, but I should be ready to show it off soon. My ECD is by the July Seattle meet. Are you going to maxus? If you are where do I send my money?
Old Jun 13, 2001 | 11:45 AM
Jeff92se's Avatar
I'm needing a caw
o2 housing. Well all of these sensors look the same to me. It just depends on where you weld in the o2 sensor bung?
I wanna see this **** in person Czar! hehe.
Maxus? Well by the votes so far, I'm no longer going.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
