ST sway bars, opinions?
Old Mar 7, 2006 | 06:03 AM
Eric95se's Avatar
The S-T bars sound like a nice setup. Anone have these on their car, or reccoment a different setup? I was thinking of going with the BlehmCo stage 2 bar in the front, would the ST (front) bar be pointless with this setup?
Old Mar 7, 2006 | 06:36 AM
Jeff92se's Avatar
I'm needing a caw
2 Different things
Old Mar 7, 2006 | 07:31 AM
Eric95se's Avatar
I know Matt's setup is different than the sway bars, but do they, in effect do the same thing (support and tighten the front suspension?) or does Matt's reinforce the frame only?
Old Mar 7, 2006 | 07:51 AM
Alex_V
Matt's part ties the lower suspention arm mounts together with a heavy duty piece of steel, solidifying the mounts, making the suspention react sharper.
are completely diffrent. Each end of the sway bar is mounted to each suspention arm, with 2 points tied to the chassis. This ties the suspention together with a bendable link. It essentially stiffens the suspention only when one arm is at a diffrent position then the other side. IE when 1 tire goes over a bump or in a corner.
~Alex
Old Mar 7, 2006 | 07:56 AM
tripleGmax's Avatar
why would beefing up your front and rear suspension be pointless?
Old Mar 7, 2006 | 08:45 AM
Eric95se's Avatar
So, in that case would adding a sway bar and the BlehmCo part be overkill if the suspension is "boxed-in" enough to not require it, or is it best to use the BlehmCo part and sway bar together?
Basially, is the bendable link preferred over solid link? Would using both be overkill?
Old Mar 7, 2006 | 08:50 AM
Jeff92se's Avatar
I'm needing a caw
Not overkill at all. But you are a bit confused:
Matt's part: Stiffens chassis
Sway Bars: Stiffens suspension.
Both add stiffness but in different areas.
IMHO, the sway bars will make a much bigger diff than matt's part. But his part is a good one.
Old Mar 7, 2006 | 10:45 AM
Eric95se's Avatar
Thnaks, Jeff. I was pretty sure that is what Matts part did, but Alex V's response confused me a bit. Next major question, there are a variety of thicknesses for the ST bars, will the 3/4 inch bar be OK or is this too close to stock?
Old Mar 7, 2006 | 10:51 AM
Jeff92se's Avatar
I'm needing a caw
Only variance is inbetween the Addco rear bar 5/8" and the ST rear bar 3/4" Stock is spagetti" hehe. I ran a ST front and ADDCO rear but both are MAJOR upgrades.
Old Mar 8, 2006 | 05:24 PM
todamax's Avatar
I've got the ST setup on my car. One of the best things I spent money on. I've still not managed to get Matt's LTB-II installed...
Old Mar 9, 2006 | 05:23 AM
Eric95se's Avatar
thanks guys!
REDinLV
Aug 15, 2024 12:30 AM
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
