headlight failure
Old Jun 11, 2001 | 10:42 PM
khrfadz's Avatar
whenever im gunna drive at night time my right headlight never seems to turn on. i always pop the hood and wiggle the wires until it turns on. can anyone explain the prob to me?
Old Jun 11, 2001 | 10:48 PM
Dirksmoothe's Avatar
superwhites
Sounds like my driver side light fixture about 2 months ago. It will get worse... You will finally pull the wiring harness off your bulb to find the wiring harness is melting, and in about two months, no amount of jiggling will get it to work. You know why? your headlight bulbs are to high a wattage and they are frying your harness. I just went to Nissan and picked up a new wiring harness for ten bucks today and after a little soddering, it works as good as new again.
The superwhites you are running, I bet they are to high wattage and it is killing your wiring harness. That is what happenned to me and your symptoms are the exact same as mine when it began.
Old Jun 12, 2001 | 11:03 AM
khrfadz's Avatar
Re: superwhites
ive had these hyperwhites on for like a year now and the problem has just been occuring recently. the bulbs are made by MATRIX and are 9004 80watts/100 or 110 high beam.
Old Jun 12, 2001 | 11:17 AM
SEguy182's Avatar
yea when i got my hyper whites, they told me to get a lower wattage to make sure that my harness didnt fry. They told me nissans have a problem with that.
Old Jun 12, 2001 | 12:28 PM
roman's Avatar
Re: Re: superwhites
That's the problem...the bulbs ar 80/100.
The harness is only designed to handle 55watts.
Go to Auto Zone or any other car parts store and buy a wire harness for $2.95 and just "splice and dice" into the factory wiring..when doing this make sure to note where each wire is. Eventhough the aftermarket harness has all black wire it is important which wire is where.
Old Jun 12, 2001 | 01:12 PM
James92SE's Avatar
2 VE's are better than one!
its not always the problem! i'm running stock wattage hyper whites and i'm having the same problem. i was having this problem even with the stock bulbs. most of the time only one light will come on, sometimes both come on, sometimes neither comes on. then while driving they'll just turn on and off by themselves. and to top it all off my brights dont work. i've had this problem for a while now and it's really ****ing me off. the harnesses arent melting or anything! i cant find the problem.
Old Jun 12, 2001 | 01:34 PM
roman's Avatar
Well..your problem is different but the thing the guy is talking about is definitley the harness. Have you thought about checking your relay...maybe that's the problem.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
