whats the first sign a bose system diein???
Old Mar 10, 2006 | 05:55 PM
red-line-racer's Avatar
i installed a aftermarket stereo in my friends 93 max when i was done installing it i heard a static noise when it was playing a cd but since i have never heard a working bose system in a 3rd gen so i wasn't sure if it was the aftermarket stereo or the amps would it be the amps that cant handle the aftermarket stereo???
Old Mar 10, 2006 | 06:17 PM
Greeny's Avatar
¯\(°_o)/¯
Bose speakers and the amps are 1ohm,most aftermarket stereos are 4-8 ohm...I have had good luck with pioneer hu's not messing up the bose speaker/amps....Even though they are4-8 ohm...
Old Mar 11, 2006 | 04:41 PM
internetautomar's Avatar
mod or sell?
if you hear static it's normally the amp failing
Old Mar 12, 2006 | 07:32 AM
vansskaterfreek's Avatar
i have 4 front bose amps and 2 rear, i have no clue if they work, but if you need them, give me $10 plus ship and they are yours
Old Mar 12, 2006 | 04:48 PM
PovCityHustla's Avatar
The stock bose system is not worth trying to fix. Rip out the whole bose system- amps, wires, speakers & source unit. Install some top quality after market gear and re wire it all! Thats the best way to go.
stock = crap
Old Mar 27, 2006 | 06:41 PM
dmr528's Avatar
I need help with my BOSE!!!!
I'm speakers are all crackling and I get high pearcing sounds. I know the recommendation is to replace everything. Is there a cheap way of doing this. I have 4 Bose speakers with NO amps. Can I use them without rewiring everything and just purchase an aftermarket cd player? Any info will help.
Old Mar 27, 2006 | 07:08 PM
how does the bose speakers have NO amps????? there should be one little amp near each speaker....... i have sets of amps if you need them.. but i dont know if they work
Old Mar 27, 2006 | 08:12 PM
CyMax's Avatar
Overall the way you can ell the STOCK BOSE system is dying, well it's the word BOSE on a 90 something car. Great for the time but far from 00+ tech. Rip it out and get with the century.
Old Mar 28, 2006 | 08:00 AM
mod or sell?
the bose system isn't bad when it's all working, unfortunately that's rarely the case.
ANYWAYS the crackling is probably the amps failing.
you can either:
a. Resolder the affected amps
b. buy replacement amps
c. replace everything since the stock bose H/U can't drive regular speakers
I'm opting for "c" since I just got 4 infiniti reference speakers and a JVC H/U (KD-G110) I may use my alpine H/U (CDE-7827)
Old Mar 28, 2006 | 08:39 AM
blackandwhite's Avatar
To them I'm like an idol
My Bose works fine. I have had all 4 amps rebuilt. (A relatively cheap fix, write-ups are available).
The last time I had an issue (rebuilding the final amp) was in 2000. They have worked flawlessly since with 3 different head units:
3rd Gen BOSE
4th Gen BOSE
The aftermarket Head Unit listed in my sig
Old Mar 28, 2006 | 11:07 AM
bluemax89's Avatar
Blackandwhite: Where can we find the write-up on the amp rebuild? I like the Boso system when it works.
I read somewhere that all the capacitors on the amp circuit board need to be replaced, but I am interested in seeing some details before I attempt anything.
Thanks man.
Old Mar 28, 2006 | 08:33 PM
dmr528's Avatar
What does it take to get put a whole new system in? Do I have to re-wire the entire car? Or can I just get replacement speakers and stereo with the right adapters? I don't have a ton of $$$, but my radio's dyin' and I need to get it fixed. Thanks
Old Mar 29, 2006 | 04:16 AM
mod or sell?
you want the easy way?
what I did / am doing
1. took out stock front housings
2. traced housing onto a piece of mdf (1/4 or 3/8 I forget which I still have some left)
3. marked mounting holes on MDF from stock housings
4. (didn't do but should have) Mark speaker mounting as low as possible and (I did the next part) cut hole in center for speaker
comes out like this:
for ease of hookup I cut the harness that goes from the car to the amp (4 wire connector) and used the purple and yellow wires to run to the speakers (front and rear connectors)
on the rear I did the same with the harness and the speakers comeout with a 1/4" socket and 4 nuts.
MOST 6x9s will bolt straight in.
for the HU, just get a regular nissan wiring harness adapter for like $10 and the antenna adappter also like $10 and swap in the HU you want.
I'll probably be selling my already wired Alpine shortly if you're interested.
Old Mar 29, 2006 | 07:32 AM
I get some static too at low volume when playing CDs with my aftermarket unit and BOSE speakers.
However, it does not happen when I play music through the USB connection, or when I listen to the radio.
MAybe it has something to do with feedback from the laser....not really sure
Old Mar 29, 2006 | 01:49 PM
4dscPat's Avatar
I have stock Bose speakers running off a cheap Kenwood headunit with the amps bypassed. I wired both left speakers in series to double the resistance, and have that running off the LF channel. Ditto for the right. Sounds fine and H avnt had any problems in over a year of running it like that.
Old Mar 30, 2006 | 02:05 AM
alextothestars's Avatar
my system still works without the head unit. and ive played the **** out of mine. looks like its hit or miss.
Old Mar 30, 2006 | 07:47 AM
chay2263's Avatar
If you hear static and a light squealling noise then they are pretty much dying.
Old Mar 30, 2006 | 01:26 PM
2k3TitaniumSe's Avatar
My bose headunit only works sometimes. Could this be a relay problem?
Old Mar 30, 2006 | 04:58 PM
RedDragon's Avatar
I have the same problems, It works sometimes and sometimes at night the light comes on and goes off randomly. I checked the wires they seem ok.
Old Mar 30, 2006 | 05:52 PM
mod or sell?
i just threw out mine because the display wasn't on half the time.
well that and I picked up the eclipse with it's H/U and speakers so it all got swapped in free audio upgrade
I pitched the bose from my first max because of a failed speaker amp or 2 or 3
never did put front speakers in that one
I do have the front bose speaker pod assemblies from this one still. though they need connectors now
Old Apr 19, 2006 | 07:09 PM
j-rad's Avatar
Maybe somebody can help me with my bose system too - I'm guessing from reading this post that mine is dead as well.
About 6 months ago the display went out, and never came back on - I learned to live without a display, but about 3 months ago the sound starting going in/out randomly. At first it seemed like it would cut out (CD or radio) whenever I put the brake on, but now it just does it all the time. It will be playing, then either just cut out totally, or make crackling/static noises and then cut out.
Also, the CD player hasn't played any CDs in about 3 weeks - just spits them back out. For the past 3-4 days I've gotten no sound at all.
Time to replace everything? I really know nothing about stereos or speakers, so I'm guessing I'll have to take it somewhere for them to rip everything out and put all new stuff in. Reccomendations?
*edit* My car is a 93 GXE
Old Apr 20, 2006 | 08:12 PM
mod or sell?
replace it.
but do it yourself.
if you know how to use a screw driver, wrench, knife and tape you can swap it all easily.
Old Apr 20, 2006 | 10:21 PM
j-rad's Avatar
can i use all the wires and everything already in there, or do i have to replace all that too?
so basically i just need to take out the cd/tape player, the speakers, and replace them with new stuff?
Old Apr 21, 2006 | 08:25 AM
mod or sell?
that's pretty much what I did.
Got a stereo, adapter harness and antenna adapter.
the rear bose speakers are 6x9s
the front bose I made some adapters out of mdf, but people have modified the stock bose housing to fit 6.5s
on the bose speaker connector there are 4 wires 2 for power and 2 for the speaker.
on mine it was purple and yellow for the speaker.
Old Apr 21, 2006 | 08:49 AM
j-rad's Avatar
do you know the size of the front speakers? maybe i can find some that are that size so i dont have to do any modifications.
Old Apr 21, 2006 | 02:59 PM
mod or sell?
4" with a 3 bolt mounting
NOTHING bolts in.
another option is to get non-bose pods which hold a 4x6 speaker
Old Apr 21, 2006 | 03:06 PM
Cliff Clavin's Avatar
Way out West
actually, you can cut up the stock front Bose housing to fit a 6.5" speaker in there. MrGone has a pic of that somewhere. It's kind of ghetto, but it works. It's not like you can see it, anyway.
You can use the stock wiring, but you have to bypass the amps and know the right wires to use. I have my rear amps bypassed and my HU power is running my 6x9s in the back for rear fill (I have an amp running my front speakers).
Old Apr 21, 2006 | 03:17 PM
mod or sell?
that was the only reason I suggested going to non-bose housings
Old Apr 21, 2006 | 03:32 PM
i have a set of speaker pods that i cut myself to hold 6 1/2" pioneer speakers.... it worked wonders for me!!!! i am not using them anymore, so if you want them, you will need NO modification whatsoever if you get a 6 1/2 inch speaker..PM me if you are interested!
Old Apr 21, 2006 | 05:04 PM
Way out West
james92se makes them, as well. His are perfect. I have had a set in my car since just after I bought the car over 3 years ago and they are still working fine.
Old Apr 21, 2006 | 06:03 PM
yeaqh, y ou cant really mess them up.... just cut a hole, and let them thump!!!!! they never gave me a problem either
Old Apr 21, 2006 | 08:32 PM
AscendantMax's Avatar
<shameless plug> i have a set of jame's pods that i don't use anymore since i have a 6th gen now. they're still in good shape. if you want them, i'll let them go for 20 bucks shipped? let me know if you're interested </end shameless plug>
MichMaxFan
Sep 30, 2015 09:18 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
