using 91 octane in my car
Old Mar 11, 2006 | 06:13 AM
wutsup
hey guys my car has over 213,000 miles on it and ive been using 87 octane. should i try 91 octane? or will it be the same as 87 because my car is so old
Old Mar 11, 2006 | 06:29 AM
Greeny's Avatar
¯\(°_o)/¯
Higher octane gas is to prevent spark knock[detonation]..If you are not experiencing spark knock.then you are probably wasting your $$$...
http://auto.howstuffworks.com/question90.htm
Old Mar 11, 2006 | 06:42 AM
kcidmil's Avatar
The only reason why I use 91 is because availability of grades. 85 has poor performance, and mileage, 89 has 10% ethanol added which is a big no no for our cars, so that only leaves 91.
Old Mar 11, 2006 | 07:24 AM
DaWifey's90's Avatar
what can my max do for me
y is ethanol a big no no for our cars?
Old Mar 11, 2006 | 07:35 AM
SouthStar019's Avatar
its supposed to be bad for the fuel injectors. at least thats what i hear.
Old Mar 11, 2006 | 09:19 AM
VEvolution's Avatar
I miss my VE
The FSM calls for 87 on the VG.
91 for the VE, but since theres no 91 around here, the next runner up is 93.
Who said theres no ethanol in 91?
Old Mar 11, 2006 | 09:41 AM
91WBSE's Avatar
The owners manual in my 91 SE says:
A minimum octane rating of 87 can be used.
For increased performance and efficiency use a gasoline with an octane rating of at least 91 or higher.
My 91 SE has run premium 91 octane since new.
Old Mar 11, 2006 | 10:36 AM
kcidmil's Avatar
State of South Dakota requires the gas stations to post which fuel is using ethanol. I get my gasoline from Sam's Club because they're the only place around that doesn't even carry the ethanol blend. There are some places around that have been fined for mixing tanks.
I've had to replace 2 injectors because of ethanol. Normally this could be written off as a rare case, but after some conversation with a friend at Nissan, there have been plenty of other 3rd gens that have come in with the same exact problem. I even compared my old injectors to those he pulled out of other Maximas', the scoring was generaly the same. Some were even frozen solid.
It's funny when I hear the researchers say the blend is generally safe for all vehicles, then you hear the butt saving qoute of "should not be used on older vehicles"
Old Mar 11, 2006 | 10:39 AM
kcidmil's Avatar
exact problems have been scoring of the injector nozzles and housing, causing the injectors to leak. Also some have been found frozen shut or open, and when broken down a gel like substance is found packed in.
I thought maybe I had old lines and such. I then flushed the tank, and installed new lines. After a brain fart after a road trip, I accidently filled up with 89 w/ 10% ethanol. Within a few hours I had rough idle, and power loss. I drained the fuel, flushed the lines, and haven't had a problem since.
Old Mar 11, 2006 | 04:07 PM
Gen3BluMax's Avatar
Hi i live in Aus and our lowest standard is 91 octane i usually run 95 but sometimes i use 98
Old Mar 11, 2006 | 05:23 PM
internetautomar's Avatar
mod or sell?
we use a different method of calculating octane in the US
Old Mar 11, 2006 | 07:16 PM
i use 89 in my car. in the north east. tried the shell V power. didnt notice any thing. and i tried for 2 or 3 tanks. it was no use paying that much for gas that dosnt do any thing. so now i just use BP or Shell 89. but i dont know if they mix any thing in there.
Old Mar 11, 2006 | 10:16 PM
MrSector9's Avatar
You will not experience anymore power from using a higher ocane. Higher octane fuels however burn cleaner leaving less carbon deposits. They usually have more additives/detergents in them.
Old Mar 11, 2006 | 10:37 PM
max89_v6's Avatar
Biggest. Ripoff. Ever. I'm sorry.
I use 91 octane for the quicker acceleration, and better cold starting and running. 89 octane made my acceleration all laggy on those cold mornings.
Old Mar 12, 2006 | 04:55 AM
mod or sell?
no 91 octane around here.
87,89,93
Old Mar 12, 2006 | 06:58 AM
Hectic's Avatar
i get the best gas milage using 87..
Old Mar 12, 2006 | 11:08 AM
Phoenix's Avatar
Lives in a Maxima
Is that unleaded? Way back when we had 98 octane here... leaded. No more.
Old Mar 12, 2006 | 04:41 PM
PovCityHustla's Avatar
Yeah im in AUS too, we got 91, 94, 95, 98 octane. 91 is the 'normal' unleaded, 94 is the ethonol crap. 95 is the mid range stuff. 98 is high performance stuff.. Ive found that 98 and regular 91 dont have much difference in mileage but 98 does give off better performance...
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
Team STILLEN
Aug 10, 2015 04:29 PM
