alternator or the battery...?
Old Mar 19, 2006 | 12:16 AM
hellboy's Avatar
Hey guys,
the car didnt start so i tried to jump start it and it worked.....only as long as the cables were connected and soo after it turned off again.....i thgt its probably just the battery ...till I spoke to some people who said its probably an alternator problem......??? wat do u guys think....??
Old Mar 19, 2006 | 12:21 AM
ColombianMax's Avatar
While car is on, disconnect Negative cable (not jumper cable but actual batter cable)and if car turns off your alternator is bad..on the other hand you can go to your local parts store and have them test your battery...well iono if they do it free over there but you can give it a shot. How old and how many CCA is your batter rating?
Old Mar 19, 2006 | 12:30 AM
hellboy's Avatar
not sure how many cca.....i know its a 2002 battery though.....the car was just standing in my driveway for a couple of months (in reall cold)....so that makes me thing that it mite be a battery problem.....
but yeah I am prolly going to take it to the store and get them to test the battery....
Old Mar 19, 2006 | 03:57 AM
Greeny's Avatar
¯\(°_o)/¯
If your battery is from 02,then replace it....It's most likely the problem...
Most auto parts will test the battery/alternator for free..
Old Mar 19, 2006 | 05:46 AM
internetautomar's Avatar
mod or sell?
You definately need an alternator (or at least to clean its connections) and more than likely you'll need a battery too.
First go clean ALL your battery connections and alternator connections, see if that remedies the dying when jumper cables are removed part.
if not, then swap in another battery, you're about due anyways.
it's very likely that your (likely) bad alternator killed the battery, you can however try to do a SLOW charge on the battery for a day and see if that helps it.
TallTom
57
Oct 14, 2025 05:16 PM
