Maxima Gauges
Old Mar 20, 2006 | 01:34 PM
chay2263's Avatar
Maxima Gauges
I want to put some reverse glow gauges in my 92 Maxima, how hard is it to do? And where do I even start? I see the two screws on the dash board but is that all I have to unscrew?
Old Mar 20, 2006 | 01:40 PM
cmachemer's Avatar
don't even worry about it
It sounds a lot more complicated than it really is. The first thing to do is pop the trim ring around your gear shift, then take out the four screws holding in the trim around the stereo (two right above the stereo and two ashtray level). Next up is take off the trim panel holding in the cruise control and related switches (another four screws, two on each side of the steering wheel). Then you remove the black trim around the gauges, which has screws running across the top of it (another 4 I think). Once you get that out, there are four more screws holding the cluster (two top/two bottom), and then unplug all the connections from the back and pull that out. Then all you have to do is pop the lens on the cluster and install your new faces and "reassemble" everything...someone else could prolly give better instructions than these, but that's how I understand it.
Old Mar 21, 2006 | 07:51 AM
internetautomar's Avatar
mod or sell?
IF you have a 92 se, you already have "reverse glow" gauges
Old Mar 23, 2006 | 01:24 PM
heresmymind
I have to goto work right now. but i will right up later for you. i did mine with halo guages. more info coming tonight.
Old Mar 24, 2006 | 10:03 AM
AscendantMax's Avatar
the gauges are easy to get to. just a lot of bolts that needs to be removed.
check out www.geocities.com/craigbrace
there should be a write up (fixing the clock) with pics in the how-to section.
Old Mar 25, 2006 | 10:51 AM
klown_phreak's Avatar
I got a set of reverse glow gauges on ebay and really it seemed like applying them in the casing took longer than taking everything apart. In the dark with only a flashlight took about 45 minutes to complete the job. So like everyone is saying, it really seems longer and harder than it really is.
Old Mar 27, 2006 | 01:43 AM
Loco7's Avatar
why no t do something a little more custom. here is a example this site has some cool stuff for gauges look threw it
Old Mar 27, 2006 | 07:09 AM
hadman's Avatar
Aye carumba ese!
Old Mar 27, 2006 | 09:26 AM
You could also try here http://importintelligence.com/FMPro?...stnew.htm&-new I believe this is the company that I got my gauges from on ebay. But don't hold me to that one.
Goffery2uned
Aug 21, 2015 09:50 PM
acw
Aug 13, 2015 12:50 AM
julian888
Aug 6, 2015 04:39 AM
