lifter vs. VTC
Originally Posted by Jeff92se
Check your thinking
the stock air intake is in a pretty good position to get cold air
If you think so
the turbulance created by the convulutions in the tubing I think would cause some power loss.
Originally Posted by MyBlue92Maxima
oh :O , ok , looks like i need to ground them and test , if i ground them and the ticking is still there , i can assume it's bad tensioners or a bad lifter somewhere , if i ground them , can i reattach the wire and make the VTC's work properly again? assuming its not the VTC's?
There is also the chance that the terminals on the soleoids are corroded, the vtc will not turn on if the terminal is corroded.
I had a bad tensioner, luckily I caught it just before doing a vtc rebuild. the tensioner would only make the chain slap at idle, if I gave it a tiny bit of gas it would go away.
when you ground the vtc you don't disconect anything, your just splicing into a wire, then connecting the other end to ground. So, yes you can remove the added wire, and return things back to normal.
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Nismo87SE
Jan 14, 2002 02:56 AM
Nismo87SE
Aug 28, 2000 12:33 PM
