BMW Headlights
You have to adjust the portion of the lights close to the grille back behind the grille. Not only will this be a more accurate aim for the lights, but also solves your problem. If you went by the write up, then where it says to place your screws for the brackets, cut slits instead so that you can loosen the nuts a little and then slide the small bolts through the slit, thus adjusting the light in/ out. These are the easiest solutions I can think of for your problem and appearant frustration.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
