5 sp Tranny conversion: Component verification
VG30E is finally out of the silver beast, '89 Max. Fixing to install my 4 year in the making, almost cost me my marriage, VG30ET. The tranny is wwwrrrrring and determined by me to be near death.
Point: Want to swap VG 5sp tranny with VE 5sp tranny. I understand that they swap out easily. However, I understand that the axles will not swap. So, here is where I need CLARIFICATION: Will the Support Bearing Bracket swap over...do the VG and VE share the same bolt pattern?
I would like to swap everything over at once. Figure easier to do this, including swapping over hub assemblies. If Support Bearing Bracket will not bolt up, then the axles at the hubs just get swapped? CLARIFY!
Please, just spell it out if anyone knows the answere enough to respond. And no "I thinks!" Either you know and have done it or you don't. I've looked and compaired Chilton's, Hayne's, and FSM's for these cars but need some conclusive response from someone who has been there. Thanks!
I've done it. I swapped the hubs over as you said(I have a pair of ve5 spindles you can have). You can also keep you original hubs and take the Vg and VE axle and frankenstien them to work. I went ahead and changed the carrier bearing, but I didn't see a difference, so I can't be of much help there.
Nismo, YGM. I re-read what you wrote so my questions for clarification really are for the most part addressed. If you changed over the carrier bearing off the VE and it bolted to the VG, then they would seem to be the same. That is essentially my only question.
I agree. I am planning to swap over hubs and all. I have a bad wheel bearing off the VE, but I can fix that down the road.
Hmmm. I didn't even think about mounts. No biggie as long as the bolt holes are there. Presently I'm trying to figure out how to remove the tie rod ends so I can replace the rack/pinion boots and bracket bushings.....while the car is down! lol !
Thanks Maxitech. I was really referring to making the effort to get them off, not how they come off. I had thought about detaching the rod from the rack, but there is this lock thing (tech name unknown) that holds it on and would otherwise be a simple unscrew. But, ran out of time. I will remove tie rods this weekend. Have already removed from hub assembly on both sides and began removal of old boots. One on Driver's side is a pain to get to even with the engine out! I've also been cleaning the engine bay with Kerosene. My wife, however, was not impressed. But, thanks!
fx4five
Oct 18, 2015 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Next.
