Fast when cold, sluggish when warm??
This is a very weird problem that i cant figure out..im not gonna act like i know a ton about cars bc im only 17 but everyone i know says that there cars are slower when the engine in cold but when it warms up it runs better...i have the opposite problem. When my engine is cold, excelleration is a lot better and it just runs great. but after it warms up it is sluggish, slow and theres a lot of hesitation. well i cant figure this one out but im sure theres someone on this forum that knows about this b/c ive never seen a problem on here that somebody couldnt answer!! thanks for any help!
Do a search for more detail but the summary is:
1) When the car is cold, it is running off preset air/fuel/idle programs. It's set rich so car feels peppier
2)When warm, the car runs closed loop and uses various sensors to determine air/fuel/ignition etc...
There is probably something wrong w/ your car's sensors that's making it run bad(or 10 other possible things) Suggestion that is easy and free. Locate the red coolant sensor's connector(on top of the intake manifold, near the fuel pressure regulator) Unhook the connector(careful), clean the male and female sides well and apply dielectric grease before reconnecting. See if that helps the hesitations.
My VE
I had the exact same problem with my VE. After cleaning the red coolant temperature sensor, replacing the fuel filter, air filter and spark plugs the Max runs smooth as butter no matter what temperature. Hope that helps.
yes...
I have the same problem, and my car feels so much slower then it used to be when i just got it with 84k, now at 103 it is completely dead.. I did the tune up and cleaned the coolant temp sensor, it did feel a bit better but after some time car felt like **** again.. and Hesitation is a major problem with mine.
Maxima SE lack of power when hot + hesitations
I have a 1992 SE with 77 K miles. It has never run well since the dealer fixed the variable valve timing system.
It is degrading and I have the same symptoms as JMaxman93. It runs great when cold, sluggish when warm.
I think it is the VTC again. If the timing is off at low RPMs, then the car will feel sluggish.
But just in case, and since I have replaced everything that wears (plugs, filters, fluids, thermostat, etc...), I will check the "Red Coolant Sensor connector".
Thanks for the trick !
Go through all of your sensor connectors and spray in electrical contact cleaner. If you have a very small flathead, use it and scrape off any corrosion. After 60-70k miles, most of the sensor connectors start showing signs of corrosion preventing good contact. The corrosion is worse if people spray water directly into the engine to clean it.
tarun900
19
12-20-2021 06:57 PM
TKHanson
11-24-2018 01:39 AM
06-06-2017 02:01 PM
