Gas Odor
Old Apr 21, 2006 | 06:28 AM
wmeacham's Avatar
Gas Odor
Has anyone ever noticed a slight gas odor around the rear seats. It is not very strong so I'm wondering if its just me. Thanks
Old Apr 21, 2006 | 07:00 AM
Greeny's Avatar
¯\(°_o)/¯
I could be one of the hoses from the fuel pump[located under rear seat] has sprung a leak...
Or maybe the filler neck has a rust hole in it...
JstAntrRoky's Avatar
Well I had an odor but I did not smell it behind the rear seats. Mine ended up being the rubber vapor tube for the gas tank running from the filler neck.
Have you removed the rear seat? If so is there any rust there? Has the rust recall been performed on your max?
That could be one reason that you smell it if you have rust through in the wheel well.
Old Apr 21, 2006 | 08:03 AM
wmeacham's Avatar
I thought the rust recall on the filler had been done. I'll remove the rear seats and check the hoses. Thanks for the advice. Wayne
Old Apr 21, 2006 | 08:42 AM
If you can post or PM me your VIN I can check for you as I work for Nissan Conumer Affairs.
Old Apr 21, 2006 | 10:30 AM
wmeacham's Avatar
I'll PM you the VIN. I'll also send you the VIN of the 2004 I just bought. Thanks
Old Apr 21, 2006 | 11:03 AM
tripleGmax's Avatar
if youre like any other rep they will tell your car is too old or your car is not in the vin list for the recall.....seen it a billion times
No problem...
Old Apr 21, 2006 | 11:08 AM
tripleGmax come on we are not all the same... All I can do is look at the information that is provided. I thought that mine would be the same case as mine is an 89 but it was still in the system as it had not been done. Now if the recall has been performed on the vehicle the vin would be archived and if that is the case it takes 1 day to de archive the vin so we can see when the recall was performed.
And by the way tripleGmax your max is sweet...
I have still not gone to the dealer myself to see about my recall and what leveal it is. I don't think mine is that bad but there is just behind the seat so they might try to buy my car back but I will want them to fix it.
Old Apr 21, 2006 | 11:10 AM
tripleGmax's Avatar
i was just giving you a hard time b/c that seems to be what nissan does to people who call about this problem....nothing against you man.
thanks for the compliment i appreciate it......
Old Apr 21, 2006 | 11:19 AM
It's all good... I just hope that I don't get the run around at the dealer when I do go and have them look at mine. From the sounds of it I will need to have another vehicle to ride around in while they figure out what they are going to do. It had taken a lot of people a long time to get there rides fixed it seems...
Old Apr 21, 2006 | 12:07 PM
Nickelrw87's Avatar
JstAntrRoky - if i PM you with my VIN number will you check that out for me too? i have a very strong scent of gas in the backseat also - EVERYONE who sits out back tells me about it
Old Apr 21, 2006 | 12:14 PM
Sure just send it to me.
Old Apr 21, 2006 | 12:49 PM
Nickelrw87's Avatar
i cant PM you yet...not enough posts or whatever - is it safe to jus type out the VIN, im sure if someone else gets it they cant do **** .... lol its not like a social security number where they can steal ya identity :P
Old Apr 21, 2006 | 01:08 PM
Very true... If you post it I will let you know what I find out.
Old Apr 21, 2006 | 01:17 PM
Nickelrw87's Avatar
ok here it is... JN1EJ01F5RT501633 THANK YOU MAN!!!
Old Apr 21, 2006 | 01:51 PM
Your vin has been archived I will dearchive it but I will not be able to look at it until Monday.
Old Apr 22, 2006 | 10:48 AM
maximamandan's Avatar
hi im in england and have a smell of petrol too could u use the vin to see if mine been done?
Old Apr 24, 2006 | 07:30 AM
Nickelrw87 I was able to dearchive your vin and it does show that the recall was performed 07/17/97 at Merchants Nissan.
Old Apr 28, 2006 | 03:38 PM
91maximase's Avatar
in my 91 se i can smell gas when i stand behind the car and sometimes when im in the car. I have took the rear seats out many times and the wheel wells down at the bottom are rusted through and thers rust all the way up the on both sides.
Old May 1, 2006 | 06:53 PM
wmeacham's Avatar
Update On Gas Ordor
I think I'm getting closer to the source. I had the car backed in the driveway. I rearly do this, I was replaceing the window regulator. While working on the car I smelled gas. When I was finished I noticed a small puddle of gas under the side of the car directly below the drivers door. I have not done more investigation yet. I wonder if it is the fuel filter. Anyone have any ideas? Thanks
Old May 1, 2006 | 07:13 PM
wmeacham's Avatar
The fuel filter is under the hood. Must be a leak in the fuel line. Does anyone know if the fuel line runs down the drivers side of the car. Wayne
Old May 1, 2006 | 07:26 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah they run directly under the driver door...poke your head under there with a flashlight and see where the leak is...
Old May 2, 2006 | 05:00 AM
MyBlue92Maxima's Avatar
put your car to the on position and get under the car, dont start it , the fuel will run though the lines like that, you should be able to find out where the leek is by just looking
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
