ways to remove crankshaft pulley w/o impact gun
Old Apr 26, 2006 | 04:03 PM
95turbo gxe's Avatar
ok how would you remove your pulley. Im waiting on my dam battery to charge to try and wedge a breaker bar againest the concreet.
Old Apr 26, 2006 | 05:03 PM
Governor's Avatar
Well you could make a tourniquet out of an old drive belt and rap it around the pulley and twist it till it so dam& tight then try to break the bolt loose?
Or put your extended breaker bar accross your control arm and crank the engine.
I used impact gun..sweeeeet!
Old Apr 26, 2006 | 05:11 PM
Greeny's Avatar
¯\(°_o)/¯
Electric impact gun ftw..
Old Apr 26, 2006 | 05:13 PM
internetautomar's Avatar
mod or sell?
Pneumatic > electric
Old Apr 26, 2006 | 05:23 PM
Greeny's Avatar
¯\(°_o)/¯
Yes they are but imo,the average shade tree guy doesn't want to spend $200 for a impact gun/$200-$300 for a air compressor...
This gun cost me $65 and has taken every bolt/nut off any car /truck i have used it on without any problem...It has even taken the control arm gusset bolts out on my maxima...
Old Apr 26, 2006 | 05:33 PM
Governor's Avatar
[QUOTE=MyGreenMax94]Yes they are but imo,the average shade tree guy doesn't want to spend $200 for a impact gun/$200-$300 for a air compressor...
Got my air compressor free (had to put new switch unit on) paid $39 for my impact gun at Lowes and it has removed every bolt I have used it on..even the axle bolts. If your going to maintain one of these older cars it is a good investment to make..
Old Apr 26, 2006 | 05:37 PM
Greeny's Avatar
¯\(°_o)/¯
Well not everyone can get a air compressor for free...
Old Apr 26, 2006 | 05:39 PM
ok no problem got the bolt off. But now i can not gfet the pulley off the crank. I had to break the last one to get it off by prying on it. So how do you get yours off?
Old Apr 26, 2006 | 05:43 PM
Governor's Avatar
6 inch 3 arm jaw puller...dont use anything smaller and dont grip the three arms on the first lip..about halfway in one of the pulley lips is about 1/4 inch thick... use this one or you will break the pulley.
Old Apr 26, 2006 | 05:45 PM
Governor's Avatar
True...but you also do not need to spend $500 for a compessor and impact gun..at least a cheaper one..but you do have a valid point...
Old Apr 26, 2006 | 05:51 PM
ok any other way to get it off?
ok where can i get a lighten aftermarket pulley from?
Old Apr 26, 2006 | 05:55 PM
Greeny's Avatar
¯\(°_o)/¯
Agreed,you don't have to spend that kind of $$ if you look around for a good deal...But most peole these days want instant satisfaction=spending $500 on air gun and compressor..
I was skeptical about this electric gun when i first got it...That was 2+ years ago and it has worked great....
Old Apr 26, 2006 | 06:03 PM
Greeny's Avatar
¯\(°_o)/¯
You need a large 2-3 jaw puller to get the pulley off there without damaging it...
MrGone's Avatar
I offered mine candy
(actually it just slid off , if it didn't, I would have used my puller)
Old Apr 26, 2006 | 06:04 PM
Old Apr 26, 2006 | 06:08 PM
MrGone's Avatar
Having the cable would annoy me.... I'll stick with air
Although using the blower tool on it is uber handy at cleaning/drying stuff aswell
still spendy
Old Apr 26, 2006 | 06:09 PM
MrGone's Avatar
That's funny, most people ask this before they pull their old pulley off
mtcookson called up Unorthadox and they sold him a blehmished () unit for uber cheap iirc.
Old Apr 26, 2006 | 06:15 PM
Greeny's Avatar
¯\(°_o)/¯
a air compressor has a hose..
Old Apr 26, 2006 | 06:23 PM
Greeny's Avatar
¯\(°_o)/¯
Mine did too,I had oil all over it from a leaky crankshaft seal though...
Old Apr 26, 2006 | 06:26 PM
MrGone's Avatar
I wanted to see if people would catch that
MrGone's Avatar
my ASP UDP needed a lot of 'candy'
Old Apr 26, 2006 | 06:29 PM
sublunary's Avatar
i used a harmonic balancer puller which worked well. but i needed to use my impact wrench to turn the puller because itwas on so tight. btw i love my electric impact wrench. ive never come across anything that it didn't have enough torque to turn. i don't have a garage so the less stuff i have to lug around (my compressor) the better
Old Apr 26, 2006 | 06:36 PM
falseicon's Avatar
I think internetautomart has em too, you should PM him
Air compressor - 25 bucks outside pawnshop one lucky day
50ft hose - 10
generic heavyduty impact w/sockets - 50 on craig's list
The 125psi (6 gal) porter cable has worked amazing well and you can find them used for about 50 or 60 fairly often. I like the ability to throw a grinder or impact hammer on there, though the small tank limits length of use.
Old Apr 26, 2006 | 07:53 PM
DennisMik's Avatar
You could connect an auxiliary tank to your compressor. At work we have a little 2 gallon compressor and we connected a 25 gallon tank for extra capacity. We did it this way because sometimes we need to take the compressor with us to a job site. And no we are not using it for impact wrenches or other air tools, just for air to blow dust out of equipment.
Old Apr 27, 2006 | 05:51 AM
mod or sell?
http://www.affsales.com/dsp_parts.cf...2FPulley%20Set
Old Apr 27, 2006 | 06:46 PM
vansskaterfreek's Avatar
i cant get my crank pulley bolt off... i used an impact wrench, but it wasnt srtong.... the motor is down the the lower block and the crank is the only thing left, so i cannot bolt it to a car... any other way to take it off.. im trying to save the crank...
Old Apr 28, 2006 | 02:16 PM
falseicon's Avatar
I'll have to do some searching to see how best to do it, maybe with a bypass valve to maximize the pressure for the impact or run from the big tank for the grinder. Hmmm
Old Apr 28, 2006 | 04:55 PM
vizslak7's Avatar
Once you get the bolt out, there are jack screw (bolt) holes in the crank pulley to remove it without a puller.
Old Apr 28, 2006 | 04:58 PM
oh really got pics on that!
Old Apr 28, 2006 | 07:46 PM
Governor's Avatar
There wasn't any jack screw holes in my crank pulley!
Old May 4, 2006 | 06:23 PM
damu's Avatar
$65...wow...Whats the torque on those impact guns.
Old May 4, 2006 | 06:31 PM
Greeny's Avatar
¯\(°_o)/¯
Don't know..But it hasn't failed to take a bolt off yet..
Old May 4, 2006 | 06:33 PM
Maxima Man's Avatar
So is it true it has jack screw holes or not ?? That would be uber nice!!
You guys who said your pully slid right off said your seal was leaking oil on it right .................. Could anyone just pour motor oil all over the shaft and see if it will slid off..........????????
Old May 19, 2006 | 10:47 PM
JET_MMPro's Avatar
I wouldn't pour oil, I'd go to the shop and pick up a can of the latest penetrating oil. We have this stinky stuff that comes in an orange can that'll seep into anything. Let it sit for an hour (over night would be better) and then try again. When I changed the seal the pully slide right off. The pully didn't have any jack screw holes. Be sure to NOT bugger up the shaft.
There are a handful of pneumatic impact guns available today with mega torque! Ingersoll-Rand Air Impact Wrench 1/2in. Drive 625 ft.–lbs. forward; 700 ft.–lbs. reverse $289.99.
---JET_MMPro
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
MaxLife17
Sep 8, 2015 02:36 PM
