Cruise Control Won't work
Old Apr 27, 2006 | 12:34 PM
wmeacham's Avatar
Does anyone have any ideas. I'd check the fuse if I knew the cruise control had a seperate fuse. Thanks
Old Apr 27, 2006 | 12:43 PM
95turbo gxe's Avatar
who's cruise does work
Old Apr 27, 2006 | 01:00 PM
ghostridden's Avatar
umm mine does
Old Apr 27, 2006 | 01:09 PM
Mr. Blue Sky's Avatar
mine used to work, until the vaccum line suddenly disconnected itself and theline where it was connected was somehow lost in the engine bay.
Old Apr 27, 2006 | 01:10 PM
«§»Craig B«§»'s Avatar
a lot of times the sensors for the brake (and clutch if 5spd) aren't adjusted correctly so it wont let you engage it properly
There are two separate switches on each pedal so make sure they're adjusted correctly.
Old Apr 27, 2006 | 01:37 PM
Maxima Man's Avatar
If its an automatic then it could be the steering wheel might not be getting power
Does the horn work?.......
Old Apr 27, 2006 | 06:16 PM
wmeacham's Avatar
It's a 5 speed. I'll check the sensors on the clutch pedal. I thought there was a light on the dash that cmae on when you turned the cruise control on. Thats not coming on either. Thanks for the advice. Wayne
Old Apr 27, 2006 | 06:27 PM
vansskaterfreek's Avatar
my cruise worked in my white 1991.. but in the 1992 it didnt.. but it had double the mileage.....i never found out how to fix it....
Old Apr 27, 2006 | 06:31 PM
geoff.doctor's Avatar
Maxima Man, My horn and cruise both work intermittantly as well. I believe the either both work or both do not work. Is that usually the clock spring? Or is the a harness somewhere?
Old Apr 27, 2006 | 07:01 PM
internetautomar's Avatar
mod or sell?
my cruise and horn work perfectly
Old Apr 27, 2006 | 07:37 PM
Cliff Clavin's Avatar
Way out West
When I bought my car, the cruise didn't work.
I looked at the system and just decided to replace the assembly under the hood (IIRC, $10 at a junk yard).
this thing here, with all the wires and stuff connected:
Disconnected the battery, swapped in the new piece, cruise works.
Otherwise, try the fuse and relay for the cruise.
Old Apr 27, 2006 | 07:42 PM
polarb68111's Avatar
Reppin Nebraska by myself
Got the same problem here, got the 92 ve auto and have never had the horn or cruise work, dont know where to start even. Heard about a relay or something though
Old Apr 27, 2006 | 07:53 PM
joe94gxe's Avatar
Dude, I've got NOS!!!1!!1!1one
Mine works too, except the fuse for my dashboard went out last weekend and I haven't had time to fix it
Old Apr 28, 2006 | 05:49 AM
mod or sell?
do you havean airbag?
Old Apr 28, 2006 | 11:52 AM
Maxima Man's Avatar
Well for all you guys who say there horn and Cruise don't work then your steering wheel clock spring is sticking so your steering wheel is not getting power sometimes or all the time...
I had the dealer pull the wheel off and unstick the spring and both have worked perfect ever since!!!!
Old Apr 28, 2006 | 10:08 PM
RyderMax's Avatar
My cruise works as long as my speedo works [grin]
Old Apr 29, 2006 | 05:57 AM
No airbag and the button on the dash that turns the little light in the dash on doesnt work either
Old Apr 29, 2006 | 09:42 AM
Maxima Man's Avatar
Then that means the cruise control is not activating!!
stevesmax
Dec 17, 2020 11:57 AM
trasmadean
Feb 1, 2017 08:20 PM
schmellyfart
Sep 25, 2015 04:47 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
