Replacing Power Window Module
Old Apr 28, 2006 | 04:27 AM
wmeacham's Avatar
My rear power window has stopped working. Looks like the cable has come off the roller and gotten jammed. Does anyone know if this is reparable or do I need a new module. Also, can I get a motor/pully assembly from the junk yard or do I need buy a new one and how difficult is it to install. Any help would be appreciated. Wayne
Old Apr 28, 2006 | 05:26 AM
Greeny's Avatar
¯\(°_o)/¯
You need to get a window regulator from http://www.internetautomart.com/
ebay has them also...
A used one will most likely fail within a short period of time...
The install is pretty easy...Take off door panel remove bolts from regulator/window assembly/unplug wire harness/wiggle it out of there...
Old Apr 28, 2006 | 05:34 AM
wmeacham's Avatar
The site says they have a window regulator and a regulator with motor. Is the regualtor the pully/cable part that attaches to the window?
Old Apr 28, 2006 | 05:59 AM
Greeny's Avatar
¯\(°_o)/¯
Yup...The regulator is the pulley cable system...I would also recommend replacing the motor too...
Old Apr 28, 2006 | 06:03 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
Yeah while you're in the door might as well replace the motor and be done with it until 2010.
Old Apr 28, 2006 | 06:30 AM
bhunter's Avatar
It is really pretty easy, a one hour job in your driveway at the most. Less if you ever do another one.
Old Apr 28, 2006 | 06:50 AM
Dougn's Avatar
I have my replaced in 2 hours. There is a write up proceddure some where in thi sfoorum. I opt to reuse the motor for two resons: First, it is easy to get open it up and replace the motor later if it gone bad. Secondly, since my is the read window and I figure I only use it 2 times per year max.
Old May 2, 2006 | 07:22 AM
wmeacham's Avatar
The regulator has been replaced. Thanks for everyones help. Wayne
Old May 2, 2006 | 11:00 AM
internetautomar's Avatar
mod or sell?
You are welcome
Old May 3, 2006 | 06:44 AM
90maxse forever's Avatar
CAn you point me to the repair procedure
Hi..
I have the same problem..rear door window doesn't work..took off the door panel and the cable is broken and wrapped around everything!
So, I need a new regulator mechanism.
Prior posts here say it is easy to replace..my take was it looked really cramped!
Anyway, I'd like to read the repair procedure..can someone help me find it or point me to it??
Thanks,
Old May 3, 2006 | 06:55 AM
mod or sell?
4 bolts on the reg, 3 on the motor and it slides up a bit, then down and out the hole.
BTW I sell window regulators
Old May 3, 2006 | 07:01 AM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by 90maxse forever
Hi..
Thanks,
http://www.geocities.com/craigbrace/
Go to the HOW TO section then find the link..
Old May 3, 2006 | 07:24 AM
Thanks for the link.
As I thought, it will take some patience to work inside the rear door!
This will be a Summer day job..when I have lots of time to kill...
Regards,
BTW..for the parts-guy who sells regulators..are they OEM? At what price?
Send me a PM..Thanks
Old May 3, 2006 | 07:46 AM
wmeacham's Avatar
I got my regulator from the link at the top of this topic. For some reason the passenger rear regulator is more $50 + $9 shipping. Wayne
Old May 3, 2006 | 11:32 AM
mod or sell?
They are aftermarket, and I've personally used them on my old car. No problems from them at all.
Old May 17, 2006 | 08:27 AM
dyme's Avatar
I replaced front left and right rear, regulators - but not motors ! Not terribly difficult,
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
maxinout93
Aug 20, 2015 02:17 AM
Mrbizness1
Aug 18, 2015 08:43 PM
kjm900r
Aug 5, 2015 07:14 AM
