Squeeky New Brakes
Old May 7, 2006 | 04:34 PM
donowprod's Avatar
Squeeky New Brakes
I recently brought my 94 maxima gxe into replace my old squeeky front brake at a local shop in Brooklyn. After 2 attempts at replacing and resurfacing the rotors and brake pads (bendix), they still Squeek. My local shop is about to tell me to go somewhere else, because they cant find the problem. Is it possible the the calipers need to be replaced? Can anyone please Help in this matter?
Thanks in advance
Old May 7, 2006 | 04:52 PM
Greeny's Avatar
¯\(°_o)/¯
Get some brake caliper grease and grease the slide pins/brake pad retainers..
Old May 7, 2006 | 09:40 PM
92 Max's Avatar
Also, I believe there is an anti squeal grease that should be put on the pad shims and BACK of the pads. This reduces squeal also. If this doesn't work, then buy the OEM pads. Sometimes aftermarket pads will squeal just due to their design.
Old May 8, 2006 | 11:59 AM
Maxima Man's Avatar
I your experience do OEM pads dust less than cheap aftermarkets ??
I also fixed my squeel with some grease.............!!
Old May 8, 2006 | 12:40 PM
92 Max's Avatar
Don't know, but doubt it. I'm trying this new wheel wax (creatively named "Wheel Wax" that is supposed to repell brake dust. When I try it I'll post whether it works or not.
Old May 8, 2006 | 02:41 PM
T93Max's Avatar
this might the same problem i have. i just found out about the squeeking this morning. i changed my brakes a few days ago. it sounds kinda like the sounds that guinea pigs make but constantly. it does it at low speed. i says around 10 to 15 mph. i thought it was the suspension.
when changing the brakes. i saw one of my slide pin is loose. it does glue onto the rubber piece like the other ones. so some of the grease were dripping out.
greasing sounds like the solution, or try some brake cleaner.
Old May 9, 2006 | 05:03 PM
nikousa2004
did u use any kind of anti sqweak spray?
Old May 9, 2006 | 05:04 PM
Greeny's Avatar
¯\(°_o)/¯
Diaf stupid nOOb
Old May 12, 2006 | 09:44 PM
dadsmax's Avatar
Cut your drums down
Old May 13, 2006 | 06:05 AM
kcidmil's Avatar
Cheap Aftermarkets are usually Semi-metallic, which is a big no no for stock rotors.
Old May 13, 2006 | 06:38 AM
Maxima Man's Avatar
I have cheap aftermarkets on the front and they dust like crazy
THEY DRIVE ME CRAZY I HATE BRAKE DUST
I am about to buy new rotors and pads I have been thinking about the green stuff pads
What material pads go with what material rotors best ?
Thanks!!
Old May 13, 2006 | 08:38 AM
slickblack94's Avatar
I bought my rotors and pads from stopcheck.com and the pads
costs about 90 dollars ,but I have had no problems with squeeling
or pad dust. I had a shop install them. They said they had to machine
the sliders to get them back to normal size but all and all they are perfect!
4 crossed drilled rotors and pads 250 labor 400 ish total 650 ish...
no squeeling at all $ priceless..... he he he
Old May 13, 2006 | 09:52 AM
kcidmil's Avatar
www.raceshopper.com the LOWEST prices you'll find. They carry Brembo blanks as well. My order was around $450, that was for 4 Rotors, Pads, and SS Brake lines
Old May 13, 2006 | 07:24 PM
internetautomar's Avatar
mod or sell?
that doesn't sound unreasonably low to me
Old May 13, 2006 | 09:15 PM
kcidmil's Avatar
When I get a front set of brake rotors for around $150, and the MSRP from the factory site is about TWICE that... yea... it's pretty low.
Old May 14, 2006 | 07:06 AM
mod or sell?
LOL, MSRP is an inflated number used to make people feel like they are getting a deal.
Monroe has MSRP at twice Jobber.
Old May 14, 2006 | 08:55 PM
donowprod's Avatar
Went back and had them install new pad and resurface the rotors again. They Still Squeek at low speed when about to stop. I have not had a chance to grease the bolts and pins like suggested. Wondering if I could use the spray anti squeek as mentioned earlier? Saw some advertised by GUNK. I live in Brooklyn, so I dont like working on my car in the street. (miss those old days of growning up on a ranch, where I could work on my vehicles.) Guess I need to Lube those parts.
Old May 14, 2006 | 09:24 PM
kcidmil's Avatar
Wow... I would have killed for a squeek when I had my Brembo slot/Napa pad setup. My Maxima sounded like a dumptruck when it stopped.
Old May 15, 2006 | 04:26 AM
89blackse's Avatar
"and falling like a rock"
Thanks!!
I have installed Brembo OEM style rotors and green stuff pads up front and I can tell you that they do work (i.e. very little dusting) In fact the front brakes dust less then the OEM rear (Smallz Brakz) which is very sad seeing as how little 3rd gen's use the rear brakes.
Shift_why couldn’t I fall for a nice domestic girl and not a Maxima
Old May 16, 2006 | 08:33 AM
MAXI's Avatar
my .02 cents:
i bought some pads at autozone, they gave me an organic brake pad, after a few miles, they started squeeking badly, i tried those anti-squeel paste thingy to no avail......finally, i replaced the pad with a semi-metallic...squeek gone!
Kcidmil........why a semi-metalic a big no no on for stock rotor????
Old May 16, 2006 | 04:26 PM
mod or sell?
Originally Posted by MAXI
my .02 cents:
WTF!
it should be the other way around. Semi-mets squeak and organics don't.
the stock (original, by now long gone) rotors are made of a softer metal than the aftermarket ones are
Old Jun 6, 2006 | 02:32 PM
dadsmax's Avatar
Take the pads off put a mask on and bevel the edges of your pads then,cut your rotors down. Reinstall the drive away nice and quiet.....
Old Jun 6, 2006 | 04:45 PM
Frakk2000's Avatar
Who needs brakes anyways.
Old Jun 6, 2006 | 04:57 PM
disgruntled's Avatar
People who want to live?
Old Jun 6, 2006 | 08:02 PM
Alex_V
(Shhh! we need some natural selection once in a while!)
~Alex
Old Jun 7, 2006 | 03:09 AM
Greeny's Avatar
¯\(°_o)/¯
"Wiking,is that you?"
Old Jun 7, 2006 | 03:25 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Originally Posted by 89blackse
What in the holy hell is this
Old Jun 7, 2006 | 03:28 AM
Greeny's Avatar
¯\(°_o)/¯
Flight 007 waiting for take off...
Old Jun 7, 2006 | 04:02 AM
mod or sell?
Beat me by an hour, dang time zone difference
Old Jun 7, 2006 | 04:19 AM
89blackse's Avatar
It's part of my on-going campaign to Stop Ricing Maxima's (Sto.R.M.)
Please people let's end the desecration of last Japanese muscle car and Not affix "wings", Sunfire grade ground kits, LED windshield washer whatevers, references and/or stickers of NOS, rims that weigh over 30 pounds each, etc...
Also this may be a stretch but can we agree that clear tail lights look good on most colors EXCEPT black? Thank you for your time.
/soapbox
Old Jun 7, 2006 | 04:39 AM
kcidmil's Avatar
Seen one worse, at least they have actual rims. While on a visit to my parent's I saw a 4th gen that was the same color, but they had bought cheap Wal-mart hubcaps, and spray painted them with purple/blue kameleon paint. I believe they were the spinners too... can't quite remember. I was to disgusted after the initial view to look back.
Old Jun 7, 2006 | 12:39 PM
92 Max's Avatar
That's one of those HD TV antenna's.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
