blinking red battery light
Old May 11, 2006 | 03:18 AM
maxima94ever's Avatar
Hi fellows i have a problem with the dash board battery light,it started when i turn on the ac,it wld start blinking, but it wld stop after a while now it is doing it when i accelerate the car {when i give it gas},can someone tell me if they had this problem before, i have brand new battery and alt., second problem is when im going uphill with my ac on the engine looses power, please help driving me crazy. Thanks ahead. JA
Old May 11, 2006 | 05:04 AM
tripleGmax's Avatar
i would check the connections and when you give it gas, i would check the voltage to see if it drops.
Old May 11, 2006 | 05:49 AM
internetautomar's Avatar
mod or sell?
1. check your idle, it may be too low when the A/C kicks in
2. the A/C system is a HUGE drain on your cars resources so it is normal to feel less power when it's going
Old May 11, 2006 | 05:59 AM
Greeny's Avatar
¯\(°_o)/¯
A/C compressor going bad??
Loose alty belt???
Old May 11, 2006 | 04:43 PM
vansskaterfreek's Avatar
when i first got my 1992, my battery and cruise light blinked ALWAYS, until it stopped until i put my head lights on... now it dont blink at all...
Old May 12, 2006 | 03:34 PM
redwood_usa's Avatar
probably a loose alt belt - or even a bad replacement alt. Do a battery test.
Old Jun 9, 2006 | 03:14 AM
update it seems to be the wiring to the alt. going to the shop today to replace it, thanks guys for ur input on the matter.
Old Jun 9, 2006 | 04:58 AM
MikAus's Avatar
Before anyone messes with the wiring, go to your nearest hardware store and buy
a spray can of electrical contact cleaner should dissolve
disconnect battery
clean + and - terminals on battery and car
disconnect connectors at your alt and give them a good spray and clean
connect batt
take car to Autozone have them test batt and alt, and pull codes
check both belts for cracks and tension replace if necessary
good luck
Old Jun 10, 2006 | 05:13 PM
colinod's Avatar
Why won't my battery light turn off. It's fine as has never failed.
Old Jun 10, 2006 | 05:18 PM
Greeny's Avatar
¯\(°_o)/¯
Chances are your alty is slowly failing,causing the light to stay on...
If your have access to a multimeter,check the voltage when it is running..It should be around 14 to 14.5 volts at idle...
Old Jun 10, 2006 | 07:46 PM
mod or sell?
I drove my old (1st gen) max with a bad alternator for a while. The alternator charged fine, but the Voltage Regulator was failing. it finally did fail, during a snow storm when I was on the south side. talk about bad timing. Driving home on a battery with no lights, heat, or wipers with RWD in a storm
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
