Erratic RPM
Old May 16, 2006 | 09:16 AM
89maxaz's Avatar
Erratic RPM
Well, I'm having some A/C problems right now- hard compressor cycling, etc., but it also appears that something else is amiss. Occasionally, the car feels like the throttle setting is changing even when accelerator pedal position is constant. Has anyone seen anything like this? Is there some sort of throttle position sensor that goes out with symptoms like this? Unfortunately, it's been 100+ degrees here for awhile now, so I can't be COMPLETELY sure that it's not the compressor dragging the engine down with the hard cycles, but the wife thinks it's happening to some extent without the A/C on. We haven't ever had any tranny problems, so I'm hoping it's not slipping or anything like that. Unfortunately, she's usually the one driving and explaining this stuff to me, and you all know how that goes! But, she hasn't mentioned ever hearing the motor race when the tach jumps around and you FEEL the RPM changes...
Any ideas or epxeriences like this?
Old May 16, 2006 | 04:29 PM
internetautomar's Avatar
mod or sell?
When the A/C comes on, the RPM goes up to compensate for the additional load
Old May 16, 2006 | 07:18 PM
sublunary's Avatar
the tps is easy to test if you have a multimeter so you should check that first. i need to replace mine.
Old May 16, 2006 | 09:10 PM
89maxaz's Avatar
In park, I held the throttle at about 2500 rpm, and while holding it there, turned the A/C on. The rpm dropped almost 500 rpm. That seems a little excessive to me.
Old May 17, 2006 | 03:18 AM
mod or sell?
try energizing the clutch and turning the compressor manually you won't think that it's such a steep drop then
Old May 17, 2006 | 08:11 AM
89maxaz's Avatar
I've owned the car for 5 years, and I've never noticed it as pronounced as it is now... I mean, if it drops 500 rpm in park at 2,500 rpm, wouldn't it KILL the engine if it cycles at idle? It usually only drops like 150 rpm or so when it cycles at idle.
Anyway, wife's got a mechanic appointment tomorrow morning for it. I'm lubing up in preparation...
Old May 17, 2006 | 11:27 AM
mod or sell?
did you clean the IAC valve?
Old May 17, 2006 | 01:47 PM
89maxaz's Avatar
Umm, no. Don't know what/where it is. I am not real familiar under the hood of this thing, as it a) rarely gives me trouble, and b) spend all my tinkering time with my Powerstroke diesel and our ATV's.
I've got a manual (aftermarket) at home. Is cleaning the IAC a fairly quick job? If so, I'll try and do it quickly tonight and see if it helps...
Thanks again.
Unclejunebug
Apr 2, 2016 05:42 AM
captchaos
Mar 15, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
