car cuts out
Old May 17, 2006 | 06:59 PM
ghostmax's Avatar
car cuts out
92 SE 5spd
My car drove fine this morning, starting without problems.
This evening, there was a rough start and then it cut out. Sounds like possible fuel pump or alternator. My battery reads 12 volts.
What tests can I run with my multimeter?
I appreciate any help!
Old May 17, 2006 | 07:16 PM
internetautomar's Avatar
mod or sell?
what volt did it read when it was running?
Old May 17, 2006 | 07:36 PM
ghostmax's Avatar
just checked it...12.1 before start, 10.4 while attempting to start. hear a little rattle coming from the back.
i've had problems with stalling for a while. recently took a 400 mile trip. noticed one rough start with a gas smell, otherwise drove fine.
Old May 18, 2006 | 03:18 AM
Greeny's Avatar
¯\(°_o)/¯
Try a tune up if your haven't done one recently...
Old May 18, 2006 | 05:28 AM
ghostmax's Avatar
car has 160k miles
new plat plugs at 130
fuel filter 10k miles ago
has jwt popcharger
vacuum tubes 20k miles
not too worried @ coils
car didnt even start this am.
can i test the alternator with my voltmeter after i remove it?
Old May 18, 2006 | 05:34 AM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by ghostmax
car has 160k miles
has jwt popcharger
Does the starter turn the engine,but wont start???
Old May 18, 2006 | 07:09 AM
ghostmax's Avatar
The engine will turn over but did not start this morning.
If my alternator were bad, would the battery still be charged at 12 volts?
Old May 18, 2006 | 07:59 AM
Greeny's Avatar
¯\(°_o)/¯
If your alty was bad it would drain your battery until it just wouldn't turn over anymore..
You need to check for fuel and spark first...
Old May 18, 2006 | 11:09 AM
Alex_V
whats the voltage with the car running? next time its running any way... It should be 14-14.8V.
~Alex
Old May 18, 2006 | 01:35 PM
ghostmax's Avatar
well i disconnected the battery, then took the MAF and checked it out. put everything back and was able to start the car.
the alternator is fine...read 14v with the car running.
will see if it starts later tonight.
thanks for the input guys.
Old May 19, 2006 | 03:08 PM
JET_MMPro's Avatar
If the battery has enough volts, with your significant other or buddy holding the key in the start position, jump the connections on the starter. Use an old (or cheap) screwdriver with a well insulated handle. The motor should start. If you’ve never done this before, don’t be startled when the screwdriver feels like you can’t pull it off.
If the battery has plenty of volts (>13v) and you think the starter is still good, then check the battery connection terminals. If you’ve had heavy corrosion one or more times in the past but not now, the corrosion may have worked it’s way between the multi strand wire enough to hinder the voltage going to the starter. Check the starter wire as well as the primary positive wire.
But, you mentioned that your max stopped running. I’d change the fuel filter. This is a cheap step and worth doing anyway.
---JET_MMPro
Old May 20, 2006 | 06:30 AM
ghostmax's Avatar
Had trouble starting the car again.
I haven't tried jumping the starter connections...not sure what you mean by that.
The positive terminal has a bit of corrosion on it but nothing terrible.
Also checked the resistance at the fuel pump harness and was okay. The harness connection itself looked almost melted. Is that normal?
I'll changed the fuel filter not too long ago, but I'll do it again. Last time, there was a bunch of crap in the old filter!
Thanks.
Old May 20, 2006 | 07:06 AM
Greeny's Avatar
¯\(°_o)/¯
Bingo!! There's your problem most likely...I have heard of a few people on here have this issue with the harness going bad....
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
lux97Max
19
Aug 27, 2015 07:48 PM
Balkins
Aug 12, 2015 06:39 AM
