WIll this really work?
Old May 21, 2006 | 02:47 PM
nForce's Avatar
The Computer Guy
Nissan Maxima Intake PPP Gasket here is the info..
2 piece insulating Intake Manifold PPP Gasket set that fits the 89-94 Nissan Maxima. Kit comes with 2 intake manifold gaskets One for each bank of cylinders. This is brand new.
These gaskets were engineered to reduce the heat transfer between the Heads and the intake manifold. The result is much cooler/denser intake charge, higher horsepower and greater reliability. You can expect as much as a 5% increase in horsepower with the use of this gasket set.
The spaceage material used in the gaskets easily handle the extreme heat output of a high performance engine. The gasket also seals on imperfect surfaces, and can be used over and over again. NASA uses this same material in multi-million dollar machinery.
I need to replace valve cover gasket so why not do this to right?
Old May 21, 2006 | 02:49 PM
goon9's Avatar
Some always asks this question once a month.....
Old May 21, 2006 | 02:50 PM
nForce's Avatar
The Computer Guy
ha guessin no?
Old May 21, 2006 | 03:50 PM
sublunary's Avatar
http://forums.maxima.org/showthread....+gasket+teflon
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
