I need to change my lower control arm bushings
Old Aug 10, 2006 | 03:51 PM
  #41
dragonminon2's Avatar
Control Arm Bushings
Here is a web site that sells control arm bushings for all 3rd gen and up maxima's they have rubber ones and Polyurethane bushings.
www.autopartswarehouse.com
i have my bushings for my 1993 GXE here
Old Aug 10, 2006 | 04:02 PM
  #42
Greeny's Avatar
¯\(°_o)/¯
Nice site.. If they work ok,this will give us another option beside the usual vendors...
Did they fit ok???
Old Aug 10, 2006 | 05:46 PM
  #43
internetautomar's Avatar
mod or sell?
Did they fit ok???
the usual vendor has the same supplier.
I just hadn't looked at them recently to notice the over-priced poly bushing
Old Aug 10, 2006 | 05:47 PM
  #44
Maxima Man's Avatar
Quick Question
If I want to just replace the ball joint could I just unbolt the 3 bolts and then unbolt the top ball joint nut and then pry it off with a pickle fork and replace with the new one in reverse order.
I just got through replacing the outer tie rod ends as well as the sway bar link bushings and my steering/suspension still clunks and makes odd noises and I just want them to all stop!! So I think I will try the ball joints next !!
Thanks for any input!
Old Aug 10, 2006 | 05:51 PM
  #45
mod or sell?
quick answer: yes
Old Aug 10, 2006 | 05:54 PM
  #46
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by Maxima Man
Quick Question
Yeah,that procedure will work...You can also use a large hammer,and strike the hub area where the balljoint slides into the spindle/hub...It should pop right out of there...
Old Aug 14, 2006 | 04:09 AM
  #47
MaximaV6's Avatar
Do you need any other tools? Maybe a ball joint press?
Old Aug 15, 2006 | 08:43 AM
  #48
Maxima Man's Avatar
No you don't I completed replacing them with the above posted method..
Thanks Guys
Matt93SE
May 24, 2019 02:58 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
00 Max
Aug 4, 2015 07:09 PM
