curse of the intake manifold gaskets
Old May 22, 2006 | 12:54 PM
92 Max's Avatar
I'm replacing the knock sensor and got new intake manifold gaskets online. When I went to put on the new gaskets I noticed one was dented and slightly bent. I flattened it and put it on anyway, but now I wonder if it will leak. Anyone have any thoughts or experience on this?
Old May 22, 2006 | 01:02 PM
Greeny's Avatar
¯\(°_o)/¯
My thought...if it's not leaking now,i doubt it will...
Old May 22, 2006 | 01:27 PM
92 Max's Avatar
The tough part is that I haven't gotten the whole thing back together yet so I don't know if it will leak. I've put the lower manifold back on, but not the upper plenum yet, so I can't test it till it's all back together, and by then there's much more time into this assembly. I also don't want to start it up and do damage.
Old May 22, 2006 | 01:44 PM
Greeny's Avatar
¯\(°_o)/¯
If it does leak when you get it back together,it is not going to damage anything...It will just run like smelly @ss..
If it was me doing the job,i would get another gasket so i didn't have to tear it apart again...
Old May 22, 2006 | 02:32 PM
92 Max's Avatar
That's kind of what I thought. I was just hoping for a different answer.
Old May 22, 2006 | 05:58 PM
sublunary's Avatar
or you could just keep going...
Old May 22, 2006 | 08:24 PM
Josh's Avatar
I don't think you will have a problem with it so long as it lines up right, because once you put the lower MF on its going to squeeze everything together pretty tight, only if there was a tear would I be worrier.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
JonBlz
Oct 5, 2015 06:02 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
