look at this pic/ whats wrong with it
Old May 22, 2006 | 06:51 PM
95turbo gxe's Avatar
Ok I just pulled off my head. and I see that one of the valve area is differant from others. what is wrong here maybe a bad injector or something!
Old May 22, 2006 | 06:54 PM
Greeny's Avatar
¯\(°_o)/¯
Looks like it has made contact with something..
<<<<<-----------Check av for the"something"
Old May 22, 2006 | 06:58 PM
MrGone's Avatar
it's missing two valves
could just be more/less carbon. middle cylinders/rear cylinders tend to run hotter.
Old May 22, 2006 | 07:01 PM
vansskaterfreek's Avatar
what was the compression on that cylinder????? why did you just miraculously take the heads off???
Old May 22, 2006 | 07:05 PM
oh I know I have bent valves but I see that cylinder is not burning as clean as the others. so i was trying to see what make it differant
Old May 22, 2006 | 07:32 PM
ohhh, ok....maybe you had a leaky seal somewhere..... did you check compression before the belt broke????
Old May 22, 2006 | 07:35 PM
yes I had great compession
Old May 22, 2006 | 09:19 PM
maxmaxima91's Avatar
that looks to me like a slight injector imbalance.. doesnt look like its enough to worry about. those valves are still pretty close in color.
Old May 23, 2006 | 10:58 AM
Alex_V
Id say dirty injector causing a inconsistant pattern therefor incomplete air/fuel mixing. Just a guess tho. If you can have your injectors cleaned or flow balanced.
~Alex
Old May 23, 2006 | 03:53 PM
-shock211-'s Avatar
hehehehe
Old May 23, 2006 | 07:03 PM
fred's Avatar
FI FTW!!!!!1111 .
Old May 24, 2006 | 01:31 PM
VEvolution's Avatar
I miss my VE
Did you figure out why that new belt snapped?
Old May 26, 2006 | 06:14 PM
nope the tensioner was in fine shape.
Old May 26, 2006 | 07:14 PM
VEvolution's Avatar
I miss my VE
I guess it's just one of those things
Old May 26, 2006 | 10:56 PM
mtcookson's Avatar
Going by the end of that plug it looks like that cylinder was running a bit on the lean side.
Old May 26, 2006 | 11:11 PM
CandiMan's Avatar
Say Candyman 5 times
If you didn't notice any abnormal engine vibration or engine miss before the belt had snap, I wouldn't worry too much about it. But I would be curious like yourself. When you get your engine back together, start pulling and reading your spark plugs on a regular basis. Rotate your spark plugs, injectors, ignition wires and see if the problem goes to another cylinder
Old May 27, 2006 | 06:45 AM
maybe the belt was too tight, and since you just installed the SAFC-2, it had so much power going throught the belt, it just ripped.......im being serious too.....just too much stres on the rubber belt, or maybe it was a defective belt????? is there ANY way to make a chain conversion??????? since you are running all that power?
Old May 27, 2006 | 08:54 AM
CandiMan's Avatar
Unlike a Chevy 350 that has conversion kits to convert your chain driven OHV to a belt driven set-up, this is a V6 FWD OHC engine s0o it's very impratical to convert a belt cam drive to a chain driven set-up
Old May 27, 2006 | 10:26 AM
MrGone's Avatar
not to mention most chain driven setups are completely inclosed and are setup for oiling where belt drive systems aren't (well they are inclosed but not to the same degree as chains)
not to mention belts offer better harmonics and are "easier" on the valve train which is why all high end race motors use them. (but also those motors are <500 mile motors and the conversion kits start from $800+)
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
