Replacing rear window..need help
Old Jun 6, 2006 | 12:03 PM
deadphish's Avatar
To start with I threw my wheel barrel in my backseat and right threw the window on the driver side..bummer. I got a window from the junkyard(have a 93' maxima gxe) and am trying to install but how does the blasted thing fit in. I have removed the door panel and vapor barrier...can someone help? I tried doing a search but apparently I dont have enough privileges to do so and I am not about to search through 800 pages of forums.
Peace,
Kevin
Old Jun 6, 2006 | 02:28 PM
deadphish's Avatar
I figured it out with some trial and error...I had to take off the braket inbetween the little triangle window in the rear door and the power window in the rear door. Works like a champ!
Old Jun 6, 2006 | 03:20 PM
deadphish's Avatar
Update..urghh..so I guess I should of tried the window the whole way up before I put the door panel back on. Well the window wont go up the last 3/4". I dont know if there some kind of adjustment or if there is a slight difference in windows from the SE and GXE version. Any thoughts? The window I got was from an SE.
Old Jun 6, 2006 | 04:03 PM
internetautomar's Avatar
mod or sell?
windows are the same.
3/4" is a LOT of gap.
the adjustment is only for like 1/8"
you sure you reinstalled all the stripping around the window?
pics would help
Old Jun 6, 2006 | 04:22 PM
deadphish's Avatar
Thanks for the advise...I reinstalled all the stripping but maybe there is a piece of glass in the stripping?..I am going to wait till tommarow when the sun is out and have at it again..if I am still having trouble I will post some pics.
Old Jun 7, 2006 | 08:55 AM
deadphish's Avatar
All figured out..it was the stripping. There was glass in some of it and I noticed the window was guiding in the stripping near the center post. All I had to do was put the window in this piece of stripping by the center post and then bolt the window onto the slider..took me a whole 15 min. to figure out with proper lighting. Thanks for the advice internetautomar! You rock!
Peace,
Deadphish
Old Jun 7, 2006 | 10:02 AM
mod or sell?
you're welcome.
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
maxipower
Aug 21, 2015 11:10 AM
