It's Alive!! (New ECU!)
Old Jun 9, 2006 | 07:16 AM
Frakk2000's Avatar
Got myself a new (used of course) ECU, and my car hummed back to life!
Also smacked on the new 18" rims and tires.
But, the car is a bit "spluttery" when its idling, could this be the ECU after reset? Or should I look for other faults? The car itself have been dead for a couple of months, so I also suspect some crap around, that needs to be blown out.
How long does it take the ECU to reset itself?
Old Jun 9, 2006 | 03:25 PM
894DSC's Avatar
Better Yet, what caused the ECU to blow out ?? Was it just bad (old age)
or was it a short ?? you could very well be dammaging the ECU again unless you checked the wiring going to the ECU (Resistance) It's great that your car is up and running again, I'm still looking for an Automatic Trans for my 89 GXE (she won't hardly make it up my driveway) But I have a new paint job !
Troy.
Old Jun 9, 2006 | 03:33 PM
Scope's Avatar
Im izz sexay
What grade of gas is in it?? Put in some premium and let her idle for about a half hour then see how she does.
Old Jun 10, 2006 | 02:29 PM
Frakk2000's Avatar
Hi,
Ive had my car in at the local nissan dealership. My old heater blew up this winter, pouring coolant into the ECU. It didnt short then, but after a couple of months it had a lot of corrosion on the inside and my car wouldnt start. (It did a lot of other weird stuff too before that).
I opened the ECU box to find a lot of the electronics had corroded away. So im pretty sure it was the ECU
Also, I suspect something with my exhaust (hole or leak), so that might explain the erratic idle?
Old Jun 10, 2006 | 03:18 PM
Greeny's Avatar
¯\(°_o)/¯
Check around the exhaust mainfolds for the leak...It may have a few broken exhaust studs,very common for these cars...
Old Jun 10, 2006 | 11:17 PM
maxitech's Avatar
Research exhaust manifold studs. It is something I will be doing very soon.
Old Jun 11, 2006 | 11:14 AM
Frakk2000's Avatar
I guess I will. Im gonna have a exhaust company that has its workshop under where I work to check it out. Im guessing the studs are crap to replace? Ive used waaay to much on this car anyway..
Old Jun 11, 2006 | 01:56 PM
vansskaterfreek's Avatar
is your car loud??? you may have an exhaust leak.... or because of the weird idle, you may have a vaccum leak.... how long was the car sitting??? just replace all the vaccum lines and you might be fine
Old Jun 12, 2006 | 12:17 AM
Frakk2000's Avatar
Its been sitting for about a month, or that is. Its working/dead for about a month at a time since Dec last year Gonna check for exhaust leak today.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
