New exhaust causing poor gas mileage??
Old Jun 12, 2006 | 11:51 AM
Eric95se's Avatar
Well, I have a Warpspeed exhaust from the heads back, but the muffler rusted out and a hanger weld completley broke off. So I replaced it with a new stainless steel magnaflow muffler. Only problem was that it was .5 inches smaller than my warpspeed pipe but the guy at the muffler shop said it wouldn't be a problem to make them fit. Well it fits, it is fully enclosed, but the pipe bends are pretty crude and I have been noticing a 3 mpg drop in fuel economy... Should I just get it replaced with a mandrel bent piece? Is the drop in pipe diameter what is causing the drop in economy? I have recentley replaced my fuel filter as well.
Eric
Old Jun 12, 2006 | 03:01 PM
maxmaxima91's Avatar
Pic's would help us get a better understanding of the situation
Old Jun 12, 2006 | 03:16 PM
sublunary's Avatar
you sure you aren't driving a bit more agressively with the upgrade? it should actually help mpg a little but it is not uncommon to take advantage of the extra power...
Old Jun 12, 2006 | 03:24 PM
AscendantMax's Avatar
well, when i had my muffler changed on my 3rd gen to a magnaflow, i found myself driving a bit faster to cut down on that damn exhaust drone. so...you maybe doing the same without knowing. faster cruising speed, milage drops.
Old Jun 13, 2006 | 03:59 AM
Eric95se's Avatar
I will post some pictures tonight.
Old Jun 13, 2006 | 10:54 AM
MrRose350Z's Avatar
reset computer after every upgrade.
#1. Pop hood
#2. 10mm wrench to unplug both power and ground.
#3. Wait one hour
#4. replace battery cables
#5. go for a drive (20 mins)
#6. FELL the POWAH!
Old Jun 13, 2006 | 11:03 AM
MrRose350Z's Avatar
The WSP piping is 2.5". If you have reduced that with a 2" pipe and muffler, then I would take it right back to where you got it done, and have them replace it with an equal pipe diameter.
You did say.5" smaller pipe right?
That's a 20% smaller pipe diameter.
Old Jun 14, 2006 | 12:24 AM
LvR's Avatar
LvR
#1. Pop hood
#3. Wait one hour
#6. FELL the POWAH!
IMO the ECU in the older Maximas are as stupid as can come and do not retain intelligent "statistics" or environment variables after switch-off with which to "tune" the control system on a continuous basis, so a complete ECU reset is unlikely to have any effect at all unless you have a really screwed-up electrical system that somehow managed to corrupt the normal workings of ECU ....................
Can you say what info you base your comment on?
Old Jun 14, 2006 | 06:12 AM
MrRose350Z's Avatar
My Hinney Meter....
Old Jun 14, 2006 | 06:17 AM
LvR's Avatar
LvR
Hinney Meter
In serious need of re-calibration I would think ..................
Old Jun 14, 2006 | 06:41 AM
MrRose350Z's Avatar
Possibly.
Mar 12, 2020 12:06 AM
ballerchris510
Sep 10, 2015 09:35 PM
dcam0326
Sep 7, 2015 07:26 AM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
