dead ve :(
Old Jun 17, 2006 | 12:15 PM
fred's Avatar
dead ve :(
i bought my brother's 92 ve5 the other night. on my way home, it died. i took off from a stop sign, and about 20 feet after i had the clutch all the way out, it felt like that 'juddering' when you are just taking off, and then it just died. and it wouldnt start again. it turns over fine, but it wont catch. so it is either fuel or spark right? anyone else had this problem? btw it was a rolling stop, and 2nd gear, and grammaing it. i have no idea why it died. i am gonna replace the fuel filter and see what that does. ngk iridium plugs have ~8000 miles on them, if that matters. any help/ideas much appreciated
Old Jun 17, 2006 | 12:53 PM
Greeny's Avatar
¯\(°_o)/¯
First thing to do is check the fuel pump,turn the key to the on position,listen for it turning on[it should run for about 3-5 seconds then shut off]
If it is ok then take one of the coilpacks out,stick a sparkplug in it then try to start it while someone is looking for spark...
If there is no spark i would suspect the crank angle sensor being bad...
Old Jun 17, 2006 | 03:46 PM
fred's Avatar
yeah the pump runs. crank angle sensor? how hard is that to replace, if that is what it is?
Old Jun 17, 2006 | 04:18 PM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 17, 2006 | 05:06 PM
fred's Avatar
schweet. is that right what i saw online in a quick search? 500 for a new one?
Old Jun 17, 2006 | 05:18 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah they are very expensive new...I would go used for this part...
Old Jun 17, 2006 | 07:11 PM
fred's Avatar
good thing one of my buddys has a parts ve.....
Old Jun 17, 2006 | 08:18 PM
Cliff Clavin's Avatar
Way out West
If you don't find one, I have an extra. I have an extra of just about everything, actually. send me a PM.
A lot of references to that part also call it a cam position sensor.
Old Jun 17, 2006 | 09:02 PM
internetautomar's Avatar
mod or sell?
well it is by the cam
Old Jun 18, 2006 | 09:08 AM
vansskaterfreek's Avatar
"camshaft position sensor"
Old Jun 18, 2006 | 10:34 AM
fred's Avatar
well turns out that isnt what the problem was. broken timing chain, hole in valve cover. /ve. 225000 miles. RIP
Old Jun 18, 2006 | 03:09 PM
Matt93SE's Avatar
STFU n00b!
from the noises you described, I was going to mention timing chain failure being a likely cause. sorry mang, but that engine is toast. www.car-part.com is your next stop.
Old Jun 21, 2006 | 12:01 PM
VEvolution's Avatar
I miss my VE
What the hell is up with these freakin' chains lately
They seem to be popping more often then VG belts on this forum
Old Jun 21, 2006 | 12:52 PM
89blackse's Avatar
"and falling like a rock"
You guys aren't making me feel good about my recent VE Maxima purchase. I hope I don't have to go crawling back to my 89 VG any time soon
Old Jun 21, 2006 | 12:57 PM
Greeny's Avatar
¯\(°_o)/¯
Buying ANY 12-15 yr old car is always a gamble...
Old Jun 21, 2006 | 01:23 PM
mod or sell?
Try buying a 10 year old car that doesn't even run
Old Jun 21, 2006 | 01:25 PM
Greeny's Avatar
¯\(°_o)/¯
Been there,done that..
Old Jun 21, 2006 | 01:30 PM
Jeff92se's Avatar
I'm needing a caw
Haven't been there, too smart to do that
Old Jun 21, 2006 | 01:36 PM
Greeny's Avatar
¯\(°_o)/¯
I only done it once..
Turned out be a ignition module[ford] Bought it for $250,drove it 2 years,sold it for $800..
Old Jun 21, 2006 | 01:41 PM
mod or sell?
turned out to be a stupid alarm malfunction.
it runs now.
smart is when you buy the car for 1/3 it's TRADE-IN value and sell it for 2x that.
Old Jun 21, 2006 | 09:33 PM
Born83's Avatar
Is that damage fixable or is it not worth it? What would cause that type of damage?
Old Jun 22, 2006 | 01:35 PM
Greeny's Avatar
¯\(°_o)/¯
Most likely what happened to his engine was the vtc end cap exploded,threw pieces of it around inside the chain cover,broke the chain,thus smashing the valves...yada yada...
IMO it is not worth fixing the engine due to the labor and cost involved in fixing the engine....You can find a ve engine in a junkyard for about $400-$800..Swap it out in a day or two,drive happy..vs having to pull the engine[much easier to fix the broken parts with it out],tear the whole top of the engine down,replace the vtc's/chains/most likely the valves/possibly pistons[sometimes valves can crack the top of the pistons when they come together]
Just not worth it to me...
Old Jun 22, 2006 | 07:44 PM
Born83's Avatar
Thanks for your response. What is a "vtc end cap" and why did it explode? how?
Old Jun 23, 2006 | 05:52 AM
replace the motor with a JDM.... or i have a motor with 72k miles in new jersey... it just needs a new head gasket..... runs perfect.....
Old Jun 23, 2006 | 05:53 AM
when the VTC's click, they usually need to be replaced sooner or later, or the end cap will explode...... it is just a poor design from nissan......thats why they went to the cheaper made VQ engine instead of the VE
Old Jun 23, 2006 | 10:58 AM
Born83's Avatar
got it, thanks
Old Jun 24, 2006 | 09:02 AM
geoff.doctor's Avatar
You can add my old 93 VE5 to the list of cars that has done that. From the service records it happened about four years ago, and had an engine with 60K put in to replace it. Now it happened again, with only 110K on the new engine. VTCs were ticking, but nothing too loud. The guy is putting another engine in it, 3 different engines in 223K miles. Now my 92 VE AT had 270K when I sold it on the original engine/tranny with no VTC tick. Weird...
Old Jun 24, 2006 | 06:56 PM
mod or sell?
not wierd.
it's the reason I prefer high mileage to low mileage.
low mileage cars normally don't recieve the same maintenance level a high mileage car does.
and on the VTCs the car needs to be running for a while to help keep the oil from gumming up the passages, something you normally won't find in a low mileage car.
Old Jun 28, 2006 | 09:29 PM
fred's Avatar
sorry to revive a dead thread, but just wanted to show a little bit of the damage. (a very small bit)[IMG][/IMG]
Old Jun 30, 2006 | 06:34 AM
DigitalMaxima90's Avatar
that looks terrible. is that part of the block.
Old Jun 30, 2006 | 06:38 AM
xavier27's Avatar
wow ive seen that before. not good
Old Jun 30, 2006 | 11:46 AM
fred's Avatar
it the valve cover and what you see is half of the chain inside there.
JRod28
Dec 29, 2023 09:56 PM
tsi6001
Oct 3, 2022 10:23 PM
markevans999
Sep 10, 2015 04:29 PM
CreativeSkillz
Aug 26, 2015 04:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
