Intake Manifold Spacer
Old Jun 24, 2006 | 10:13 PM
Duckman540i's Avatar
VE Powah!!!
You think the VE would see decent gains from an intake manifold spacer like the 350's & G35's get? I do notice that after (ANY) type of driving, the intake manifold will be extremely heat soaked. The reason being, is that it's right on top of the block. I don't know, any ideas? Maybe Matt93SE could come up with something, Like he did with his Throttle Body Spacer.
Old Jun 25, 2006 | 04:54 AM
sublunary's Avatar
iirc arron92se and some others have made there own out of sheets of teflon.
Old Jun 25, 2006 | 05:56 AM
internetautomar's Avatar
mod or sell?
it wasn't teflon they used, but they have made their own.
A search will yield the answer
Old Jun 26, 2006 | 04:38 PM
mrkanda's Avatar
Taking my Maxima to the Max!
haven't I seen something on eBay like that? I'm not sure if it was for the VE.
Old Jun 26, 2006 | 05:00 PM
Greeny's Avatar
¯\(°_o)/¯
You are definantly mistaken on this...They are exclusively custom...
Old Jun 26, 2006 | 05:11 PM
mod or sell?
VG had them on eBay
Old Jun 26, 2006 | 05:21 PM
Greeny's Avatar
¯\(°_o)/¯
had them
Fat lot of good that will do him...
Old Jun 26, 2006 | 06:53 PM
fred's Avatar
well think that if the air is cooler what kind of gains are you going to get simply from that. also, you make the intake runners longer, this helps your low end. my bad it was actually aaron92se who had the IM spacer. i remember seeing it on his list of mods site
Old Jun 26, 2006 | 07:54 PM
mrkanda's Avatar
Where do you see that? I was looking on Blehmco.com and don't see it. Is there another website? And is there one for the VG?
Old Jun 26, 2006 | 08:49 PM
Matt93SE's Avatar
STFU n00b!
I have some throttle body spacers made for the VE, but haven't put them on my site yet. too lazy to get it updated.
Old Jun 27, 2006 | 01:26 AM
VE Powah!!!
Well I'm not neccessarly saying you'll get more power, just less heat soak. That Iron Block loves to stay hot, and so the the manifold.
Old Jun 27, 2006 | 05:46 AM
MrRose350Z's Avatar
MY VG used to get a lot of heat soak, untill I traced all the little coolant lines...
I noticed thet there were two coolant lines running through my intake manafold. One was passing right through my dual trottle body, the other was passing under the rear manifold by the PCV(sp?) valve.
I took off both of them and routed them back into them selves, eliminating any HOT coolant passing through my INTAKE manifold.
I expereinced a much cooler manifold, even on warm weathered days, the rear of the manifold was cool; especially the throttle body area.
Could the VE have some of these MISC coolant lines on it's pretty little manifold?
Old Jun 27, 2006 | 06:48 AM
Mizeree_X's Avatar
Getting back to his roots
Aaron used teflon to make a manifold spacer for his VE. The problem is that the EGR pipe then doesn't fit, so he just sealed it off on both ends. But for someone who cares about emissions, you'd have to modify the EGR tube so it can fit.
Old Jul 3, 2006 | 02:55 PM
Aaron92SE's Avatar
NWP Engineering.com
Yeah, I did use teflon from McMaster Carr. And I did have to block the EGR. I also couldn't use the support plates on the back of the upper IM anymore. It doesn't hurt anything as long as you don't lean on the IM.
Also, the upper IM on the VE has no coolant running through it at all. Only the throttle body does.
This issue has been discussed an aweful lot and I've gave reviews on almost all of them.
http://www.iwdwebdesign.com/maxima/TBSeat.html
Old Jul 4, 2006 | 10:57 PM
nismology's Avatar
The spacer that the 350Z/G35 guys use is to add volume to the plenum to make more power, not to prevent heatsoak. Two different things.
Old Jul 5, 2006 | 12:28 AM
JClaw's Avatar
But I think it's made from a material that reduces heat transfer from the lower to upper thus keeping the air cooler and denser inside for a few more ponies.
Old Jul 5, 2006 | 07:12 AM
vansskaterfreek's Avatar
i think that if you put this spacer in, it helps your top end or your lower end, but then it makes the opposite worse....
Old Jul 5, 2006 | 10:24 AM
Alex_V
Its more TQ.
Think of ITB's on most imports. They are really short compared to a normal intake, and they love high RPM, not low end. A spacer would make just a little more TQ in most cases. In the Z33/G35 it gives both because 2 cyinders aren't getting all the air they need.
~Alex
Old Jul 5, 2006 | 05:31 PM
VE Powah!!!
Aaron how long did it take you to make that spacer?
Old Jul 6, 2006 | 05:19 PM
Aaron92SE's Avatar
NWP Engineering.com
A few hours to dremel it out and port match it.
Old Jul 6, 2006 | 06:31 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
how thick is it because i have a lot of 1/4 inch aluminum lying around enough for about 4-5 of those doing a prototype on the second gen with the IM gasket
Old Jul 6, 2006 | 07:19 PM
Aaron92SE's Avatar
NWP Engineering.com
I used 1/4" for both upper IM and TB. For the TB, you could easily do a 1" spacer if you lengthen the throttle cable harness plate.
Old Jul 7, 2006 | 07:11 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
sweet but ill need diff bolts for the tb, any ways thanks for the info
Old Jul 8, 2006 | 06:27 PM
Aaron92SE's Avatar
NWP Engineering.com
Oh yeah, those are easy to come by. On the VE, you can take some bolts from the upper IM (which are much longer) and use them on the TB.
Or you can just visit the hardware store.
aw11power
Oct 10, 2021 04:57 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
JonBlz
Oct 5, 2015 06:02 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
