92 Maxima Heater Control Lever Stuck
My 92 Maxima GXE heater control lever won't go lower than the mid point, moves only from mid point to hot. The result is the A/C cannot cool. I pulled the facia panel and radio, there appears to be no problem on that end of the cable. Has anyone had problem and want was cost to resolve? My dealer wants 2 hours labor to give estimate due to needing to pull panels.
Bill Doran
Bill Doran
Bill Doran
Bill Doran
On the front passenger side, look right above the ECU and see where the cable is binding. I think the color of the cable is light blue. After you take the kink out, your slider should move freely.
I'm assuming it's the same for the SE, too, huh?? I have that same problem. I will get into the dash today and let U know what I come up with. Oh, and thanks for the helpful tip, superdesi!!!
i have the same problem only i dont have a little **** thingy and my temp control wont go past where the blue meets the red (its stuck on the cold side).
anyone know where i could get a new **** thing and how hard it would be to install it?
thanks
-PaT-
92 SE 5 speed. gots some wierd noises.
thanks
-PaT-
So, yours is kinda the opposite of what I'm having. I'd just cruise a 'u-pull-it' junk yard, and ****** one of those *****. Otherwise, your best bet is buying the **** from Nissan. I don't think it's too hard to install it, though. I thought they were held on by friction....
thanks
-PaT-
'92 SE 5 speed. wierd noises could be damaged lifters or VTC, but i didnt think VTC was that loud.
'86 bmw 325. dont wanna sell but i have to
Temp control panel wasn't too hard to take off. I believe there are only 4 screws, and the panel will come out. But don't pull too hard, because everything will still be connected behind it. Now, I may be wrong, because I haven't taken my panel off since winter time. But I'll let you know about it today, though....
now...anyone know how much a new **** thingy would cost?
also, price for a window regulator? and why would my speedo randomly die?
TIA
-PaT-
'92 maxima SE 5 speed. wierd noises need to be fixed dammit!
'86 bmw 325 that i dont wanna sell
Window regulators are a shade under $60, shipped from Courtesy Nissan. You can find the link under the "links" section.
Not too sure about your other two questions. I could speculate about the speedo thing, but I don't wanna look like a total
thanks for all your help
-PaT-
'92 SE 5 speed. noises need to stop
'86 bmw 325 :*(
I just went through the same problem. My girlfriend's 92 SE exhibited the same symptoms. I went to a junkyard and pulled a new one. They wanted 40 dollars, but I declined. I went and pulled hers apart and realized I oculd move the lever from BEHIND the unit. The solution to the problem was greasing the lever in the front of the unit. I actually used Neosporin, as I didn't have grease! I know it sounds odd, but a lack of grease makes this **** very sticky. It had NOTHING to do with the cable binding up. Try the easy fix too.
If you have to pull the unit, it's not hard. It's recessed behind the dash. tilt it sideways and bring it out. Get your head underneath and manipulate the lever- I bet it works. If it does, your answer is to grease the front side of the climate control unit.
Before making this discovery, I put so much force into moving the lever that I snapped the **** off. Luckily, it's made to snap off and it clicked back in.
Let me know how it works.
MikesChevelle
Mar 2, 2021 11:32 AM
trasmadean
Feb 1, 2017 08:20 PM
Finkle
Sep 27, 2015 09:53 PM
laparka66
Aug 6, 2015 09:36 AM
