found feature on accident
who knew that theres a safety lock in the trunk of the car? i was moving a week ago and i accidentally triggered the safety lock (trunk was full of items) and had to take the back seat out to get back in to the trunk (the trunk unlock mechanism had no effect on the trunk with the safety lock down)!
heh; i also replaced the rear drivers side window motivator and motor. the replacement just broke somehow today when i was rolling it up. wtf. i know i bought the car for $2k and i love it, but this damn thing is nickel and diming me to death! at least the fixes are usually simple and work...most of the time.
Originally Posted by grinder
i have two maximas, 92 gxe auto, and 89 se fully loaded 5spd, both of them i only have a copied key for them and the key won't work in the door or the trunk and is hard to use in the ignition too
where do you get the key code?
Originally Posted by mszilves
Do you have pics of the location of the safety lock switch? Where exactly is it...
I think?
sorry to inform you guys but you will be out of luck if you try to get a key cut with the VIN. They started keeping those records in late 94 I believe. Everyone I know that has tried (including me) to get a key cut with the vin has not been able to. So far I havent seen anyone come up with a key code either. I saw it mentioned and some people said it was in the glove box but no one has found it. It is probably in the sales pack you get when you buy the car but not many people keep that stuff.
Im on my 3rd copied key. Broke the other 2 while sitting on them while driving a hi-lo. (stupid keychains that go on belt buckle)3rd key works on all doors, trunk and ignition.Then I have my spare that i made.Didnt work on nothing.Took a small file. Filed lightly on teeth. Opens pasenger door, trunk and ignition.
would i still be able to get a key made without the key code?
huh...did you read my post?
You can always get a key made by making a copy of an existing key but you just cant get a new one cut by the VIN.
If you go to a good lock smith and not walmart or a hardware store you will be able to get a good copy made even if your key is worn. Heck I had a locksmith make me a master key with a valet key. I locked my keys in the trunk of my old MR2 but luckily I had my valet key in my walet. Well that wouldnt open the trunk so I went to a locksmith and they knew exactly what the difference was and made a perfect key that worked the trunk, door and ignition.
Not sure if there are many quality locksmiths left though.
the only decent locksmith (or real city) around here is about two hours drive from here so i was trying to avoid that if possible.
basicly i wanted to know if i could still get one from nissan, which i belive the answer is no.
you can buy new blanks from them but thats about it. Most of the Nissan dealers I know of have a key cutter that goes by a code...without the code they can do nothing.
But like I said you can buy a nice blank key with the big black plastic that says Nissan on it and take it to a locksmith or any place that makes keys and have a copy made.
cool, thanks for the info. that saved me alot of hassle more than likely
IIRC, the key code is stamped onto the ignition cylinder. It should also be stamped onto the door lock cylinders. I'm pretty sure it was on my 90 240SX so logic would dictate that it would be the same on our cars, since they're from the same era. But since when did logic mean anything?
Otherwise, if you have the original key ring from the dealer, it will have a little 5mm by 20mm tag affixed to it with the key code stamped onto it. I was lucky with my old 240 and had both original keys, the valet key, and the key code tag.
As far as the trunk safety lock goes, I found that a while ago by accident too. Of course, I was reading the manual when I happened upon it.
but it was by the code I gave them.
and they also told me that they can't go back farther than 94 from the VIN
my dealer just cut mine on a generic blank
yeah they want top dollar for those original style blanks. I got a couple for my old Altima I had and I think I paid like $5 or more for just the blank.
So where did you get the code then.
2. it was in the glovebox on a sticker, same as my current one is.
MaxLvr21
Oct 17, 2015 12:11 PM
