turn signal indicator bulbs
Old Jul 22, 2006 | 08:02 PM
traxtar944's Avatar
Would be lost w/out the org
anyone know what type of bulbs are in the instrument cluster behind the turn signals? I thought it would be cool to make them red.
Old Jul 22, 2006 | 08:17 PM
evil pete's Avatar
194's I think, should be the same as the markers for the corners, but then again, I may be wrong. Also, the actual lens of the indicator might be green.
Old Jul 23, 2006 | 09:14 AM
traxtar944's Avatar
well, the lense behind the turn signal is green, but the bulb is no 194....it's bigger. I figure if the bulb is bright enough, it should over ride the green plastic behind the arrow, or the green could easily be changed to something more see-through and color-less.
Old Aug 11, 2006 | 11:30 PM
elusivemax93's Avatar
the turn signal green indicator peices are juz peices of plastic u can remove them when u take out ur cluster and disassemble it
Old Aug 12, 2006 | 02:31 AM
maximal's Avatar
i bought led bulbs that were 74 and they fit perfectly. the piece of green plastic does change the color, quite a bit. i bought blue bulbs and the look aqua. my color scheme is blue and turquoise, so it worked in my favor.
Old Aug 12, 2006 | 02:53 AM
craigl33's Avatar
speaking of turn signals, my right one doesn't turn on anymore. is there some fuse i should check or how do i replace the bulb?
Old Aug 12, 2006 | 06:43 PM
cmachemer's Avatar
don't even worry about it
Are you talking about the front right one? There are two screws that hold it in the bumper...take those out and disconnect the harness that goes into it and you can replace the bulb. As for a fuse for the turn signals, I'm guessing that it's covered by the fuse labeled "Turn" in the Driver's Side Dash fusebox.
Old Aug 13, 2006 | 07:41 PM
traxtar944's Avatar
alright....so it's a 74 bulb. Thats good to know. It's funny though. I'm starting to like the green turn indicators. They contrst well with the blue. I think I might make them red though. We'll see. I'll post pics of my finished interior as soon as I finish putting the leather on the drivers seat. It turned out pretty nice though. I got the ambient lighting working, so it's like a BMW or Acura inside. I had to route a wire from behind the dash up the trim on the A brace, and through the headliner with a coathanger. It looks soooo sweet though. Very classy.
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
LtLeary
Sep 14, 2015 12:33 PM
minsbang
Sep 11, 2015 08:48 PM
