Rear fenders rusted through - to fix or not to fix?
Old Aug 8, 2006 | 06:09 AM
Tarzan's Avatar
The rus has eaten thru the metal just behind the rear splash guards.
How much does it cost to fix and is it worth fixing?
Old Aug 8, 2006 | 06:32 AM
internetautomar's Avatar
mod or sell?
the real question is can you weld?
if you can , then cut it off and make some patch panels to weld in.
if you can't then don't bother.
Old Aug 8, 2006 | 07:43 AM
Tarzan's Avatar
No, I can't weld.
Old Aug 8, 2006 | 08:37 AM
Alex_V
if you cant, get some treatment spray from advance or w/e and find some one that can weld.
~Alex
Old Aug 9, 2006 | 05:34 AM
Tarzan's Avatar
I've put a bottle of RustCheck everywhere underneath, under the hood and in the trunk etc. The cars don't last forever, I knew it was coming. I'll drive it to the ground and let it rust at its own rate.
Old Aug 10, 2006 | 07:50 AM
5.0_junkie's Avatar
If you can not weld it is probably going to cost you alot more than you are willing to shell out. Just drive into the ground man!
Old Aug 30, 2006 | 09:22 AM
gen3fan's Avatar
I asked about rust repair tips here awhile ago, at the time concerning the right front strut starting to break through the strut tower (it was actually starting to push that side of the hood up!). I was advised to not bother, cuz there was bound to be other body or structural issues elsewhere that haven't popped up yet, and I'd be chasing the problems forever. Well, I didn't have the cash for another Max at the time, so I had a bud patch weld it back together. He did an awesome job, and it's fine after a year later. BUT since then, a bit of rust at the rear wheel wells and rockers turned so bad, it won't even pass inspection! Also, when I went to change the rear struts, similar problems. So, consider how far you want to go with it.
I now have an almost identical '93 in much better shape, and I plan to use the former as a parts car.
Old Aug 30, 2006 | 09:53 AM
89blackse's Avatar
"and falling like a rock"
Can you take a pic of it? It may not be that bad. I patched many holes in my rear fender wells. Many holes
Course now my floor is rusting through...hum wonder if pine would hold up.
Old Aug 30, 2006 | 11:33 AM
Black92GXE's Avatar
Boomer Sooner
Thank God I live in a less wintery/salty part of the country - no rust what so ever on my 92!!!
vingodine
45
May 21, 2016 12:46 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Huttig2009
Sep 25, 2015 03:31 PM
laflyer23
Aug 22, 2015 10:04 PM
