Help With Guage Cluster...
Old Jun 25, 2001 | 09:49 AM
crsmax's Avatar
Does anyone know how to remove the needles from the 89-91 GXE guage cluster???
I tried to pull off from the top, and the black cap is the only piece that came off. I tried to remove assembly that has pin that needle connects to, but no luck there either. Any suggestions?
Old Jun 25, 2001 | 10:27 AM
C-Dawg's Avatar
I read somewhere in here before that you can twist them counterclockwise and pull up at the same time. I am not sure who posted that, but I believe it was ngthing. Ask him, he'll help you out.
Old Jun 25, 2001 | 11:52 AM
Isaacm's Avatar
ahh, yes...
been there, done that, meshed 'em up...
finally did it right and just got my hands on some SE guages and everything went good from there.
I have heard of people successfully pulling out the needles, and I only messed up one of the four switching mine out the first time, but one is enough. I got my SE guages for like $50 at the bone yard. And is accurate within 1 mph and 50 rpm.
Old Jun 26, 2001 | 06:35 AM
crsmax's Avatar
Re: ahh, yes...
Issac,
Sorry to hear that you messed it up, but the question remains, how did you remove it???
Old Jun 26, 2001 | 08:27 AM
Isaacm's Avatar
Re: Re: ahh, yes...
Issac,
From what I remember, use a spoon and pry up, between the guage face and the clear plastic neddle base, while turning counter-clockwise. It is supposed to work, but obviously didn't so well for me. I wish you luck!
Just curious, what is your reason for taking off the needles? Is it for ngthings overlays, or what? They do look nice, but I prefered the style of lettering on the SE guages anyways.
Old Jun 26, 2001 | 09:15 AM
crsmax's Avatar
Re: Re: Re: ahh, yes...
Just curious, what is your reason for taking off the needles? Is it for ngthings overlays, or what? They do look nice, but I prefered the style of lettering on the SE guages anyways. [/B][/QUOTE]
Ahh... Ancient Chinese secret... Actually I'm customizing my SE guage cluster... Thanks for the info. Counter-clockwise and pry huh?
What happened that you broke yours?
Old Jun 26, 2001 | 12:26 PM
Isaacm's Avatar
Re: Re: Re: Re: ahh, yes...
What happened that you broke yours? [/B][/QUOTE]
I guess I didn't turns them enough why prying up. The metal pin came up along with the clear plastic base. Once the pin comes up, there is no way to re-seat it and work correctly. Trust me, I tried many times, many hours.
Soooooo... are you putting a logo or graphic on the guage faces? coloring the needles?
Old Jun 26, 2001 | 01:47 PM
crsmax's Avatar
You guessed it...
Actually, I'm trying to color the needles, is there an easier way? Please let me know... I'm really interested.
Old Jun 27, 2001 | 05:42 AM
Isaacm's Avatar
Re: You guessed it...
I tried to color my needles a really bright blue when I was doing the overlay thing. It didn't work with the GXE needles: there is the orange paint, then white over it. I used fingernail polish remover to get rid of the orange/white, and it didn't look too bad. It just wasn't bright enough to see at night; very dim.
But, since you are starting with SE needles, it might just work, and look good at night too. When you are done, post a night pic.
Once again, good luck. I had less headaches doing all four struts than working with those needles, and the pins coming out and all.
Old Jun 27, 2001 | 08:58 AM
crsmax's Avatar
Re: Re: You guessed it...
Lol!
Isaacm,
You were right! I was able to pull all of the needles by turning counter-clockwise and pulling at the same time. I really only had trouble with one (temp. I believe), anyway the trick now will be to swap out the needles and get everything to align and work properly again. I will let you know how it goes. I will try to post some pics when I'm done, but the dash should end up looking similar to this:
Cotozic
Jun 28, 2017 08:01 PM
rnb754
Sep 14, 2015 11:39 PM
95Maxi
Aug 25, 2015 08:01 PM
