OEM Throw out bearing. Deffective?
Old Aug 30, 2006 | 10:36 PM
  #41
VEvolution's Avatar
I miss my VE
Wow that BBK looks awesome
Old Aug 31, 2006 | 12:54 PM
  #42
Maxpwer's Avatar
No turbo, no care!
Originally Posted by Chris Gregg
Anyone have any issues out of Spec TOB's? I hate hearing stuff like this! Ignorance is bliss!!!!!
I would agree that the spec TOB is atleast as good as OEM, but I've only got 30k miles on mine so I wont say for sure. But, I will mention my car tends to see several 6000 RPM clutch dumps (with the 6 puck) a week, and so far so good. That cheap TOB bearing that I posted earlier lasted about 1500 miles.
Old Aug 31, 2006 | 12:58 PM
  #43
Maxpwer's Avatar
No turbo, no care!
Originally Posted by 505max94se
The car drove fine for about a week and then it got stuck in two gears at once (reverse and 2nd) while it was parked. I had to take it apart two other times (while it was on the car) to figure out what was wrong. I finally fixed it by making my own check ball pin and it works great now...
I had the exact same problem after I rebuilt my trans. I used the exact same method to fix it and also havent had a problem since.
Old Aug 31, 2006 | 02:03 PM
  #44
505max94se's Avatar
I was pretty mad when it happened because I wasn't the one who lost the pin in the first place. I actually used a craftsman star tip screw driver, the diamete was perfect. All I had to do is cut the screw driver shaft to a perfect length and round the ends with a bench grinder. It works perfectly now.
Old Aug 31, 2006 | 02:05 PM
  #45
505max94se's Avatar
I've destoyed a spec TOB in 10k miles... ACT FTW!!
Old Aug 31, 2006 | 02:15 PM
  #46
Jeff92se's Avatar
I'm needing a caw
My car lives! Sean, thanks for taking care of it. But I know you are abusing those brakes.
Old Aug 31, 2006 | 02:20 PM
  #47
505max94se's Avatar
I did this a couple months after I got the car.
How do you know I'm abusing the brakes?
Old Aug 31, 2006 | 02:23 PM
  #48
Jeff92se's Avatar
I'm needing a caw
Because they can take it. heh. How is the old girl?
Old Aug 31, 2006 | 03:58 PM
  #49
Jeff583's Avatar
[QUOTE=505max94se]First of all you don't need to heat up any of the bearings to remove them. Second, I would only replace the front input shaft bearing, the others should be fine, just inspect them.
It makes it much easier and if you heat up the bearings to remove them, they will slide right off this way, but if only the front is bad, then only replace that one unless you want to do the whole thing.
Old Aug 31, 2006 | 06:03 PM
  #50
505max94se's Avatar
Yes they can take alot...I've already had to replace the pads. lol
She's doing great down here in NM. Everything still is just as nice (or maybe nicer)as when I bought the car. I just started using the yota filters and the lifter clack is MUCH better.
Old Aug 31, 2006 | 06:04 PM
  #51
505max94se's Avatar
Yes it would be easier if you don't have a hydrolic press...
Old Oct 12, 2006 | 03:48 PM
  #52
goon9's Avatar
She's on jack stands now
Getting tore down for a new input bearing. It wasn't bad to the point where I was losing gears. Just REAL loud now.
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
atriuum
Sep 28, 2015 01:19 PM
