No reverse or dash lights
Hello,
If anyone knows what relays operate reverse lights and dash lights, any information would be greatly appreciated.
I have pulled out my last strand of hair trying to figure it out.
Thanks,
Hillstreet
Thanks,
Hillstreet
I just had that problem about 2 weeks ago. I believe you have a short and that is why your dash and reverse lights are not working. What you should do is check your rear lights and pull every bulb out to see if the connectors are melted together. Again, pull out the rear light assembly and pull every bulb out and if one or more are stuck is because they are melted at the base. Also check the wires to see if they are making contact. After you have done that make sure that you do not have any blown fuses. Good Luck!! Let me know what happens.
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
