Clunk Clunk!!!!!!!!!
Old Aug 27, 2006 | 10:35 AM
Maxima Man's Avatar
I need help finding the cause of a clunk in my front suspension I seems to be at the worst when going over bumps ...
I just recently replaced my balljoints and the sway bar link bushings and the tie rod ends ...
I think it might have gotten alittle better at first but now it is like it was before again!!!(MAD)
What other bushings are there up front that could cause clunks ?
I don't think it is my CV joints either because they are not torn but I guess they still could go bad ?...
If my lower control arm bushings are bad will it cause this metal to metal clunk sound?
Thanks for all input given!!!!!!!
Old Aug 27, 2006 | 10:59 AM
Greeny's Avatar
¯\(°_o)/¯
Strut mount bearings?
Could be a cv though,does it clunk while turning or just over bumps??
Old Aug 27, 2006 | 11:27 AM
sublunary's Avatar
i doubt it is the ca bushings. are your struts and strut mounts in good shape? are you sure its the front and not the back?
Old Aug 27, 2006 | 12:24 PM
Sgibb's Avatar
when i had a clunk from my car it was the lower control arm bushings
Old Aug 27, 2006 | 03:59 PM
Maxima Man's Avatar
It is in the front for sure and it clunks while turning or going over bumps
How can I check the condition of the strut mounts ?
Sqibb what type of clunk can you be more descriptive?
Old Aug 27, 2006 | 04:36 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like a cv axle to me..
Old Aug 27, 2006 | 04:44 PM
Maxima Man's Avatar
Greenmax I just asked my dad and he said the CV axles are 1 year old with less than 300 miles on them so I doubt its them ........
Old Aug 27, 2006 | 04:59 PM
Greeny's Avatar
¯\(°_o)/¯
Old Aug 27, 2006 | 05:10 PM
slickblack94's Avatar
I would guess strut mounts.Mine clunk on bumps and brick roads,and when flying over rail road tracks he he he
Old Aug 27, 2006 | 05:13 PM
Greeny's Avatar
¯\(°_o)/¯
Yellow brick roads??
Old Aug 27, 2006 | 05:41 PM
Josh's Avatar
1 year and less than 300 miles? who are you Cliff Clavin? but really that does sound like a CV axle to me too.
Old Aug 27, 2006 | 06:57 PM
Sgibb's Avatar
If i hit the breaks too hard i would hear a loud clunk and when i went over some bumps i would hear it squeaking too
Old Aug 27, 2006 | 07:10 PM
Josh's Avatar
Wheel bearing maybe? I don't know man this is wierd.
Old Aug 28, 2006 | 04:08 AM
sublunary's Avatar
im not sure how you can check the mounts other than just looking at them but if they've never been replaced it could be more than a coincidence.
Old Aug 28, 2006 | 08:24 AM
92 Max's Avatar
Does the front wheel squeek or chirp. If it chirps it could be the brakes. Did you check the tightness of the brake mounting bolts ( and also the suspension bolts). If these are not tight they will cause clunks.
Old Aug 28, 2006 | 03:18 PM
sublunary's Avatar
use a torque wrench, they can be too tight as well (strut tower bolts)
Old Aug 28, 2006 | 04:23 PM
Maxima Man's Avatar
Well I am leaning towards the strut mounts and Its sometimes a clunk while hiting a bump but also there is another noise is heard when just driving straight and it sounds like a pop noise that has alittle bit of tap noise to it as well and you will here this once every 1-2miles sometimes much more frequent...
How much do you think a shop might cahrge me to replace the strut mounts I know its pretty straight forward but I just don't feel like screwing with the springs..
Thanks for the ideas!!!!!!!!!!!!
Old Aug 28, 2006 | 06:52 PM
dv3's Avatar
dv3
lol.....brick roads ......cant say i ever had the opportunity to take my max on one of those
Old Aug 28, 2006 | 08:40 PM
sublunary's Avatar
it is straight forward and you can borrow spring compressors from autozone for free. you should do it yourself. im not a mechanic and i changed my struts and springs. it was easy, you can look at a write up on here and just look for the info about the mounts.
Old Aug 28, 2006 | 11:00 PM
Hectic's Avatar
jack her up, inspect and tighten anything loose.
the car....the car
Old Aug 29, 2006 | 09:06 AM
Maxima Man's Avatar
OH OK THE CAR..........
I might do it myself if I look at it and It looks simple enough ....
I checked and everything is tight under there and I have replaced all but lower control arm bushings ......
Any idea what the pop/snap sound might be
Old Aug 29, 2006 | 09:31 AM
internetautomar's Avatar
mod or sell?
Old Aug 29, 2006 | 01:54 PM
Maxima Man's Avatar
How much could I buy the lower arms from you without the balljoints (already replaced them)
Thanks...
You think thats half the prob the lower control arm bushings?
Old Aug 29, 2006 | 03:39 PM
mod or sell?
the bushings on these cars tend to go bad especially the right front when there is an oil leak there ( I went through 2 in a year or so)
I can sell you arms without *****, but the pricing difference is only like $5
Old Aug 30, 2006 | 08:41 AM
Maxima Man's Avatar
why arent the ***** like 30.00?
Old Aug 30, 2006 | 10:02 AM
maxitech's Avatar
If it is the strut mounts, you can save money by taking the strut assemblys of and taking them to the shop. I would let them deal with the springs, though.
A good indication that it is the control arm is if there is abnormally high tire wear on the inside edge of the tire.
Old Aug 30, 2006 | 10:08 AM
mod or sell?
because I don't generally buy them seperately for the arms, they come packaged with them.
Old Aug 30, 2006 | 04:27 PM
Pepi's Avatar
umm my car clunks on both... so the turning would be? control arm? and over tracks/bumps strut? or actually sound more like a banging noise? could that be bearings i dunno
Old Aug 30, 2006 | 04:33 PM
Greeny's Avatar
¯\(°_o)/¯
A "clunk clunk clunk clunk clunk clunk" sound around turns is a common sign of a bad cv joint..You can "feel" it in the body of the car when it clunks...
Old Aug 30, 2006 | 04:49 PM
Hectic's Avatar
have you ruled out where the lower ball joint connects to the steering knuckle? if that nut is loose, it will definitely produce a clunking sound although your stability will also be affected when turning which you haven't mentioned. just an idea.
Old Aug 31, 2006 | 03:55 AM
Maxima Man's Avatar
I changed out the ball joints and I guess it could have worked loose but it does have a saftey pin through it so it won't go that far
Thanks I will check it out!!!
Old Aug 31, 2006 | 05:27 AM
Tarzan's Avatar
The CV joints make noise when you turn your steering all the way either side while moving. It's click-click-click-click-click-click-click....
Clunks on the straight line over the bumps is not CV, not ball joints either. The ball joints make noise when the wheel drops, when the wheel rises, they are quiet.
I think it's the strut tower mounts or control arms.
Old Aug 31, 2006 | 08:47 AM
Maxima Man's Avatar
Thats what I think too thanks for conferming my suspisions......
I think I might get a shop to replace my front struts and the mounts as well as the lower control arms..
Old Aug 31, 2006 | 10:28 AM
Tarzan's Avatar
Front strut job is a 2-3 hour DIY fun, if you have good spring compressors. There is my write-up somewhere in this forum dated 2003-2004, and lots of other's write-ups. You basically borrow the spring compressors from a store, do the work and return them. You need a set of wrenches besides that. Very straightforward and saves you lots of $$$.
Rear struts are a bit trickier, but it's only in the part where you have to remove the gland seal nut, which I recommend doing by bolting the strut to a wheel and turning the cap with adjusting plyers. Then there might be some grinding on the bottom of the new cartridges if you get Kyb GR2 and they are tad too tall. That's it.
Old Aug 31, 2006 | 01:24 PM
4dscPat's Avatar
What about the outside edge? My car is lowered on Eibach springs.
Old Aug 31, 2006 | 03:57 PM
Maxima Man's Avatar
Tarzan how the hell do you know all about suspension work but you don't know how to change your oil and sparkplugs.........
Old Sep 1, 2006 | 04:52 AM
Tarzan's Avatar
'cause I was pulling your leg and some bought that
Old Sep 1, 2006 | 09:35 AM
dadsmax's Avatar
Just change out the drive axles. They could be coming apart inside the boots may still be good but it is the guts that count. The could be rebuilt and porly done and change both at the same time. Not a hard job to do. Or just get stuck on the road at night in the dark somewhere
Unclejunebug
Apr 2, 2016 05:42 AM
msellas
Sep 23, 2015 09:16 PM
ColdCananda
Sep 20, 2015 10:45 PM
